Question about Marantz Audio Players & Recorders
When playing a CD using my Marantz Integrated Amplifier PM4200, the 'mute' light flashes and obviously no sound comes out. This is now happening with about 75% of my CDs. There appears to be no way to stop this happening as there is no actual mute button on the amplifier. There is a mute button on the remote, but this has no effect whatsoever on the problem. What to do, please?
robotek
  • 1512 Answers
SOURCE: My Marantz PM-45 integrated amplifier
Hi HouseofBlues
The problem you are facing is the speaker protection is turning on to prevent the amplifier from damaging your speakers. It will need some service work done to it to prevent it from happening. I suggest you get it attended to sooner than later, as the problem will be caused by dry solder joints that will need to resoldered, or a semicinductor that is failing. If you are a gun with a soldering iron, you could do this yourself. Check about parts of the amp that runs hot, particularly transistors and resistors in the output stages. resolder all output transistors, and any parts that are mounted to a heatsink. Also focus on areas of the PCB that has discoloured. This is often where the problems occur.
I am more than happy to answer any other questions you may have about it, just give me a hoy :)
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 02, 2008
  • 7 Answers
SOURCE: I believe an amplifier problem
I had a problem with no audio and I recently found the fix. When thesub still worked and you turn it on you hear one relay click and thenabout 5 seconds later a second relay clicks and the audio comes on. Theproblem I had lies with that second relay. When you take the case apartthere are 4 circuit boards. The big board with the two big bluecapacitors is the main board. Well next to the two blue capacitors is ablue relay. That relay had a pin that came un-soldered from the circuitboard. I re-soldered that pin and the sub works just like new. If yougo here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.htmlyou can find a free service manual that has the wiring schematics forthe amp. Hope this helps!
Posted on Jul 13, 2008
robotek
  • 1512 Answers
SOURCE: Vintage Stereo Connection ???
Hi spanky
Where to start :) I am excited thinking about them :p You got 2 totally cool pieces of classic vintage gear there in the C2 and the Marantz. I have a C2 preamp myself (gathering dust but wont sell it cos its excellent) and the marantz would be totally cool to have(but then I am a little biased towards 70's vintage marantz). They ruled the roost in HiFi amps throughout that decade.
Because they are both integrated amps, you could use them as standalone systems with a pair of speakers, and just plug your favourite gear into them. If you just wanted to run up a nice sounding HiFi, I would sell the kenwood gear and just keep the Marantz. The Kenwood kr1100 has the edge in power, so if it is grunt you are looking for use that. Because vintage sound is all about stereo, you only really need an integrated amp to get great results.
the specs are
# Kenwood Model Eleven G (KR-11000G) Receiver
120W per channel min RMS, both channels driven, at 8 ohms from 20 to 20.000 Hz with no more than 0.03% total harmonic distortion.
Dynamic power output 440W at 4 ohms
Power bandwidth 5 Hz to 70.000 HZ
Frequency response 5 Hz to 100.000 HZ -1.5dB
Signal to noise ratio 115dB
The marantz is a little lower in power at 75rms a channel, but will have the sonic edge in vintage sound over the kr1100. Look them up on ebay and you will find that they do have some value to collectors and people seeking nice tone. There is an 1152 for sale here for AU$900
Best bet is to fire up the 2 integrated amps,and see how they are going. Run them for several hours to be sure there is no strange noises and crackles. Then decide if you want power or finesse.
You could also run both amps from the C2 preamp by connecting to the Amp in connections to the rear of the integrated amps.
happy to talk to you more about it, hit me with a Fixya if my advice was helpful to you. I would keep the marantz, use that and sell the rest and buy some nice speakers:)
regards
robotek
Posted on Jul 21, 2008
robotek
  • 1512 Answers
SOURCE: Kenwood KR11000G and Marantz 1152DC Integrated Amplifier
Hi spanky, replied to one of you other posts. Just clearing this ticket out of the system:)
robotek
Posted on Jul 24, 2008
SOURCE: my marantz sr19ex amplifier has
I am working on one right now, it has blown output transistors and several upstream transistors and burned resistors as well. This channel of the amp will need a rebuild.
Use a volt meter and, with black lead on the chassis, check the voltages at the 3 conductor connectors going to the board at the rear speaker terminals. These are the outputs coming from the amp and if there is voltage on any of these (unit at idle, no volume), the protection circuit will keep the output from getting to the speakers. High voltage here means blown amp, most likely.
feel free to contact me regarding the repair... www.irebuildmarantz.com
Posted on Nov 08, 2008
Red flash light blinking.
That's a short circuit indicator. If you have some electronic skills u can repair it, else send it to a repair shop.
Apr 20, 2014 | Marantz PM6004 Integrated Amplifier
My marantz sr 5200 has stuck in "Mute on" situation
Your mute switch has been broken some how,End will have to be replaced.
Oct 11, 2012 | Marantz SR-5200 Receiver
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
I have a Teac a-R600 integrated amp. The muting light strarts to flash after about an hour playing and mutes the sound until unit is switched off and re started. Any ideas . Thanks Ian
YOU ARE GOING TOO FAR IN VOLUME CONTROL AND YOUR AMPLIFIER TRY TO PROTECT ITSELF BY MUTING-MAKE YOUR VOLUME LITTLE BIT DOWN.IF THE PROBLEM REPEATED WITH LOWER VOLUME SETTING YOU WILL HAVE INTERNAL PROBLEM.ANYWAY CHECK YOUR CABLES FOR GOOD CONDITION.
Dec 19, 2009 | Audio Players & Recorders
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
Hi spanky
the specs are
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
53 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
