Question about Maytag Washing Machines
Maytag LAW9406AAE-serial-11267061QW Blowing breaker as soon as I pull start button--Last attempt took 32v-25a fuse out also.Thinking it could be lid switch??
  • 69mrlonely Dec 31, 2010
    Definitely a shorted wire--unhooked all components one by one and still have short--also changed start switch and still have short.Unable to pin point but definitely in the wiring harness.Thanks richroth.Your info got me on the right track!
    Top Expert:
  • Maytag Master
  • 9,472 Answers
No, the lid switch won't have anything to do with it. First, open the cabinet and look at the wires on the capacitor located on the back of the cabinet under the water inlet valve or on the motor. Check for any shorts. Second, look at the start switch located on the motor, it is where the wiring plug is plugged into the motor for any loose or broken wires. Third, open the top control panel and look at all the switches for ant loose or shorted wires.
Posted on Dec 29, 2010
Remote mirrors not working
Start by checking the 15A DDM and 10A PDM fuses in the left I/P fuse block. If the fuses are OK, the 25A LT DOORS circuit breaker in that fuse block and/or the 25A RT DOOR circuit breaker in the I/P relay block may have failed.
Apr 16, 2014 | 2004 Chevrolet Avalanche
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Washer won't start
see the instruction. God bless you
  1. No power to the washerMake sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
  2. Lid switchThe washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Read more: http://www.appliancepartspros.com/repair-help/washer-repair-help.html#1#ixzz2Ze5OnT54
Jul 21, 2013 | Maytag Neptune Washing Machines
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
The in-line 1a fuse blows as soon as you pull the button out to start the machine.....could that be a lid switch or a fill level switch
It is actually called the check switch which is located in the same section as the lid switch. Part # 207166
Jun 12, 2011 | Maytag LSE7806A Top Load Stacked...
Washing machine keeps triping the breaker. reset breaker but wont turn on at all now. how can i access the electrial wiring to see if anythings shorted out
Most of these Top-Load Maytag machines, allow access to the controls, by removing two screws on the top of the top control panel--
Remember to pull the plug from the wall before getting inside the control panel section.
When you remove the two outer screw, the panel itself will tilt forward, giving you access to the insides.
Most models have a control fuse inside, that may have blown-- Can you see it toward the back, and the middle. Does it look blown?-- can you replace it.
Note: I found on my machine, that the 2 switches that are connected to the lid get sluggish, and can result in blowing the control fuse, with the dropping of the lid!--
I found that I had to make sure the Control knob was always IN whenever we move the lid up or down.
Let me know if this helped-- or if we need to dig deeper.
Mack B
Jan 27, 2011 | Maytag Legacy Series Top Load Washer
Start your wash machine
If your washer doesn't seem to work at all, check these: No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 01, 2010 | Maytag PAV2300 Top Load Washer
The trunk lid does not pull down
check 25A fuse in relay center
Apr 17, 2009 | 1991 Cadillac Eldorado
No sounds or movenent
Possible bad lid switch. You should hear it click when lid closes; if not in needs to be replaced. Inexpensive part. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
