Question about Nikon COOLPIX L2 Digital Camera
L2 Lens Error
My Nikon Coolpix L2 camera one day suddenly, on powering on the lens came out and a started emanating burring noise from the lens assembly. After some time the burring noise stopped but the screen showed "lens error" message and did not switch off. On keeping the power switch pressed when the camera was tapped a couple of times the lens retracted and the camera switched off. This repeated everytime I switched on the camera. At times while tapping the camera suddenly starts working normaly, but switching off is possible only after tapping the camera while keeping the power switch pressed. Any suggestions what am I supposed to do?? Thanks..
  • matthewH Sep 05, 2008
    Same problem but lens is left half out. Outer two segments want to move but the larger segment appears jammed. Same burring noises and lens error note. Have tried manually (gently) easing lens to no avail. Don't really fancy bashing table. Is this a design fault of the camera???
  • Anonymous Sep 09, 2008
    L2 is showing len's error and will not retract.
This didn't work for me!
Posted on Aug 23, 2008
I just gave it a very hard tap against my dinning table and it became alright!
Posted on Jul 18, 2008
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Lens error on nixon s520 coolpix?
Hi there lens eooro occur when the lens guide pin is damaged or dislocked. So i suggest you plzease visit service center. Thanks.
Exam image
Mar 23, 2010 | Nikon COOLPIX L2 Digital Camera
I am getting a lens error message on my nikon coolpix L2 Camera
Try cleaning out any grit in the lens barrel with compressed air and wiggling the lens gently. If that doesn't do it, the camera needs servicing.
Oct 04, 2009 | Nikon COOLPIX L2 Digital Camera
Lens error
I believe the gears from the lens mechanism are broken. It's expensive to repair. Is better to buy a new camera with better quality.
Aug 19, 2009 | Nikon COOLPIX L10 Digital Camera
Lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Jun 02, 2009 | Nikon COOLPIX L2 Digital Camera
Lens error
i had the same problem....my problem was the lens was pushed forward and the third zoom was pushed back. so the lens is blocking the cover(thing that covers the lens) so push the lens back carefully with a cottom swab and pull the third zoomer thingy out.
Jul 31, 2008 | Nikon COOLPIX L2 Digital Camera
Lens Error on NIkon CoolPix L2
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 31, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon coolpix l2
I had this issue and I read on the net to hold the lens down on a table of some sort and apply slight pressure while pressing the power button, it should go right back in, It did for me!
Jul 29, 2008 | Nikon COOLPIX L12 Digital Camera
Lens Error unable to switch camera off
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 27, 2007 | Nikon COOLPIX L2 Digital Camera
Lens Error-Nikon L2
It seems as a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 10, 2007 | Nikon COOLPIX L2 Digital Camera
Nikon COOLPIX L2 Digital Camera Logo
350 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
