Question about Mag Nif Ultra Sorter Motorized Coin Sorter
How do you turn on the Ultra Sorter Motorized Coin Sorter
There's a button on the top back right side you press.
Posted on Jul 22, 2011
Brandt coin counter and sorter, looking for a manual for it, not sure of model, have a pic of it
No one can give you a manual with out a model number! There are hundreds of models. A picture would be helpful.
Call me, I may have one if I can "see" the machine.
Harry 985 / 893-52four one
Nov 11, 2013 | Retail Supplies
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
It says error code C0b63 what does it mean
All Cob codes on this series of Minolta copiers pertain to the sorter. Most all of the time you can simply open and close the sorter to reset the code. By open and then close I mean that the sorter must be pulled away from the copier then closed back.
Make sure there is nothing interfering with the movement of the sorter bins.
If opening/closing does not reset the code or if the code comes right back after resetting then the sorter will need service as dis-assembly/repair/re-assembly will be required. You can also unplug the large connector going from the sorter to the machine and use the copier without the sorter. If you have a 10 bin sorter that "hangs" from the side of the machine then you can leave the sorter attached and it will work fine unplugged. If you have the 20 bin sorter that sits on the floor then the sorter will have to be moved away from the copier if unplugged to prevent the machine from jamming. If you unplug the sorter be sure to turn the copiers power off before disconnecting the sorter.
Good Luck and Thank You for using Fixya.
WheatlandService
Nov 11, 2010 | Minolta EP4000/5000 CS/PRO Copier
Model SF2530 photocopy Erroe F1 how to reset
F1 00 Content Sorter communication trouble Detail Communication line test error occurs when power is turned on or after the exit of a simulation mode. Improper communication with sorter Cause Improper connection or broken wire of connector or harness between copier and sorter Sorter control PWB defective Control PWB (PCU) defective Malfunction due to noise Check and remedy Clear by turning the power supply OFF/ON. Check communication line connector and harness. Replace sorter control PWB or PCU PWB. F1 02 Content Sorter transport motor error Detail Transport motor drive trouble Cause Motor lock Check and remedy Check transport motor operation with SIM3-3. F1 03 Content Sorter guide bar rocking motor trouble Detail Sorter guide bar rocking motor drive error Cause Motor lock Motor speed error Overcurrent to motor Sorter control PWB defective Check and remedy Check guide bar motor operation with SIM3-10. F1 04 Content Sorter indexer lower limit detected Detail Indexer has exceeded lower limit. Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 05 Content Sorter indexer upper limit detected Detail Indexer has exceeded upper limit Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 06 Content Sorter bin shift motor error Detail 1) Bin shift is not completed within 2.5 seconds after bin shift request Cause Motor lock Improper motor speed Overcurrent to motor Sorter control PWB defective Check and remedy Check bin shift motor operation with SIM3-4.
Jan 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier model SF2530 F1 flasing and copier
Hello sir; F-1 is sorter problem, did you connect sorter with machine, turn power off and check th connecter .
May 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Canon NP 6025 Sorter error
if you tell us what the problem or error code is ??????????????????????
Sep 10, 2008 | Canon NP 6551 Black and White Copier
CanonIR 5570 Copier reboots then jams at sorter
Sounds like the sorter connection between the two is poor or disconnecting, check the cable from sorter and power lead to the sorter are secure.
Check switch that machine uses to know when sorter is engaged is closing proberly/not bent
Check sorter indicator lights (if any) after reboot,
Try running lead to it from elsewhere in case there is too much drain or something weird with power supply where you are
Jan 12, 2008 | Office Equipment & Supplies
Mag Nif Ultra Sorter Motorized Coin Sorter Logo
167 people viewed this question
Top Mag Nif Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Mag Nif Toy Expert? Answer questions, earn points and help others
