Question about Humidifiers
Do u have to see water flow in? - Humidifiers
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
yes if the unit is on and calling for humidity, yes you will see water flowing, you should hear a loud click and the water turn. and the motor turn, if you have a drum type system..you did not give a make and model
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 29, 2010
No water flow through solenoid
The water flow through the humidifier is limited/controlled by an orifice. This small opening can easily clog. After disassembly use a small wire to clear the debris trapped in the small hole,
Hope this helps?
May 18, 2017 | Lennox Healthy Climate HCWB3-17A...
Should water be continualing running through the drain tube?
Water will flow over the filter pad as long as the unit is calling for humidity. once the unit is satisfied the solenoid valve should stop the water flow. if the water continues to flow with out call then solenoid valve has failed open. hope this helps.suppling an owners manual in case you need one.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 600 Humidifier
When the solenoid activates I have water coming out the top of the solenoid. When I connect the metal tubing which goes from the solenoid to the top of the unit no water flows. The metal tubing has a...
yes, the water will flow to quickly without it. you can use a very small dill bit to clear it. if it flows to fast you can control it using the shut off valve. hope this helps.
Dec 20, 2010 | General Filters 1042-LH Humidifier
I have a model #560..turning the humidistat forward until it "clicks" would cause the water to begin flowing..now, after the "click" is heard, the water does not flow into the reservoir. Do you think it's...
turn the saddle valve in and back out. sometimes the small pin hole for the water gets plugged with something over the summer when the units aren't running and just turning the valve in and back out clears it out and allows the water to flow. check to see that you have water flow at the solenoid and if you do then it is probably the solenoid that is bad.
Dec 07, 2009 | Aprilaire Humidifiers
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
Too much water wasted
The oriface is sized for the proper water flow for the model you purchased. If you are dissatisfied you could throttle down on the saddle valve to restrict the water flow to the unit.
Good luck
HVAC Teacher
Jan 31, 2009 | Aprilaire 600 Humidifier
Fan running but no water flow
the humidistat on this unit just acts as a set of dry contacts. with the humidifier plugged in, you should be able to touch the 2 brown wires by the water solenoid together and get the power fan to run and the water solenoid to enrgize. if you do this and water does not flow, you most likely have a bad water soenoid. it is either electrically bad, or just plugged with water deposits. sometimes you can pull it apart and clean it, sometimes you just have to replace the solenoid.
Jan 26, 2009 | Aprilaire 700 Humidifier
Solenoid on Aprilaire 600
solenoid valves dont just burn up just like that you have a recurring restriction due to bad water.Check the saddle valve at the water heater first then check for postive water flow at inlet to the solenoid valve,if you have water flow the valve is clogged with sediment.
Dec 13, 2008 | Aprilaire 600 Humidifier
No water flow to the humififier
I've been working on the Aprilaire 110 unit today, after encountering the same problem. Here's how I fixed it: First, with the humidistat turned to 0%, I turned off the water supply saddle valve all the way (all the way to the right)--and then turned it back on all the way (all the way left). Still no water flow. Second, I slightly loosened the inline valve nut on the discharge side of the solenoid on the side of the 110 unit. Water began flowing, so I tightened it back up; and now the water flows freely. Conclusion: You may have some mineral deposit buildup in your lines, as I apparently did.
Nov 25, 2008 | Aprilaire 600 Humidifier
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Humidifiers Logo
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
