Question about Runco CL-410 Multimedia Projector
I have a Runco CL410 projector. The problem that I have with it is after about 40 minutes of watching a movie the high speed fan kicks in. It goes off and on about every three minutes. The lamp has 650 hours on it.
    Problem Solver:
  • 14 Answers
Sounds like it may have some dust build up. Do you know how to open the case and clean out?
Posted on Feb 28, 2011
Projector keeps switching itself OFF
The projector is probably overheating you need to check fans and lamp inside
May 28, 2008 | Audio Players & Recorders
Runco cl-610 projector
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Jan 05, 2013 | Runco Lamp for CL-610 Projector
I have a Runco CL-810 projector, how do you clean the fan filter?
Filter will be located near the intake fan. You can remove it and clean it. Normally just blow out the dust. If it is oily you can use dish soap be sure it is fully dried before replacement. The fans you can blow out (with machine off) Be sure not to spin them too fast or the bearings will be destroyed.
Dec 16, 2012 | Runco Cl-810 Reflection Dlp Projector Lens
How do I replace the bulb hours in my Runco Media VX-4000d Projector? I already replaced the bulb. Thank you for your help!
Please contact Runco support at 1-800-23-RUNCO. We can assist you.
Sal Di Giacomo
Runco International
WW Service Manager
sal.digiacomo@runco.com
Aug 05, 2011 | Runco VX-5000ci Multimedia Projector
Vidikron vision 40 2003 Power will not come on now and no power light. Occassionally will come on after 10 minutes after turning on but then shut down
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video For similar problem on Runco projector. Very easy fix.
May 23, 2011 | Vidikron Office Equipment & Supplies
My projector turned off in the middle of watching a movie. One of the indicator LEDs which gives coded blinking for different problems with the projector says there is a problem with the lamp temperature....
hi,
check the fan one more time . may be its speed is low. if it not rotate at the correct rpm, the lamp will get over heated. check the fan if available replace it and try again.
ok
Jan 14, 2011 | NEC LT245 Multimedia Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Infocus x1 projector
Indeed, the problem you describe is the Color Wheel. Very common issue in the X1,2 projectors. Unfortunately the only fix is to replace this wheel. The cost of the part generally runs around $175 but the labor to replace is about the same. You will need to find an authorized service center where you live or send it to a repair facility. Parts for any of the InFocus units are generally not available to the public, alas the Service Centers. Maybe for the same cost you could look at a new projector, like I did.
Jan 18, 2008 | InFocus X1A DLP Slide Projector
Screen goes blank after 5-6 minutes but sound continues
It may be overheating, check fans and or obstructions of the vents
Sep 02, 2007 | Runco CL-410 Multimedia Projector
200 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
