Question about Sylvania Computers & Internet
Can not get intrnet service, lower right side bottom has xx on the computer screan, what should I do?
    Genius:
  • 1,267 Answers
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Posted on Dec 29, 2010
I'm unable to get rid of digital display boxes at the bottom of my screan
See previous answer to almost identical question you posted.
Mar 16, 2012 | Hitachi Televison & Video
I want to change back to yahoo classic mail.please do the needful.
ON THE RIGHT HAND SIDE OF YOUR SCREAN HIT OPTIONS AND THEN HIT CHANGE BACK TO CLASSIC MAIL,,,,,,,[THIS IS WHEN YOU ARE IN YOUR MAILBOX,,,HOPE THIS HELPS.
Jul 15, 2011 | Yahoo Mail
1997 Honda CBR 1100 XX. Bike builds idle slowly when cold . right side exhaust is forceful and hot while left side exhaust in minimal and warm only. Changed plugs and made no difference. Seems to idle...
Clay, you have a tiger by the tail. There are a lot of little parts to the carb system. I will try to assist you in the basics without carb removal. This may require a few replies back and forth. Start by turning off the gas then drain the carbs. Now turn on the gas and check to see that fuel flows into each carb. If gas starts flowing out of all the float bowls, now that the gas is back on, then all carbs are getting gas. To drain the carbs just remove the drain screw on the bottom of each carb float bowl. Two carbs have the drain screw on the left, two have it on the right side. Reply with what you find. tombones49_51.gif
Apr 03, 2011 | 1997 Honda CBR 1100 XX Super blackbird
LG 42 inch plasma. Half screen is ok (rh side) other side black
Buffer boards or Y-SUS main needs to be replaced. What do you mean by motherboard? The power supply board or the Logic or X main.... They YBU/YBL and the YSUS work in unison. Y-Buffer upper controls top half, Y Buffer lower control bottom have YSUS controls both of those. There is also D, G, E F boards that can split screan. But they to are controlled with the Y-SUS Main. Hope this helps...
Jun 29, 2010 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Dvd play back has a line from top of screan along
try reinstall converter drivers and software. if persists try to send to repair, maybe a converter board defective.
Jan 16, 2010 | ION Audio VCR 2 PC USB VHS Video to...
I want to V2000 laptop driver. 1.multimedia Audio controller 2.Network controller 3.PCI modem 4.SM Bus controller 5.video controller
First, Right click my computer, click manage, then go to device manager from the opened window. Then, right click on your 5 specified components, and click update driver. this should automatically try to update them online.
Failing that.... the following is the long winded way of doing things!
This site should do the trick. look at the exact model number on the bottom of the laptop, it should say;
HP Compaq Presario V20zzxx
[where zz is 2 numbers for the exact model number] [where xx is 2 letters in lower case]
(you'll see what i mean when you click the link) select the relevant link from here and click to download
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
Oct 15, 2009 | HP Compaq Presario V2000 Notebook
How do I enable a disabled speaker?
right click on the volume down the bottom of your screan then click on playback devices and your speakker will be there if not you have to download the latest update for them
May 10, 2009 | Audio Players & Recorders
2007 John Deere 6920 Tractor foot trottle not working
Turn the key on and hold the scroll switch down until the dash comes up dia.the scroll switch is the same one that you use to change from engimne rpm to pto rpm on the right lower side of the steering columb.Once you see the dia screan then hit the right signal lever,the screan will change to all.Turn the hazard flasher switch on for a second and record the codes and controllers that appear in the dash.A j.d. dealer will be able to tell you what to look for according to this code list.
Mar 29, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
E:62:12 keeps flashing on my camera
We had the same problem, Sony DSC W80 with the code E 62:12 flashing on the upper right side of the LCD screen. The camera was rotating the photos by 90-degrees. After reading that E 62 was related to the steady shot function, I figured it may be a stuck potentiometer in the camera (it has little sensors that tell the camera what it's orientation is, I guessed one of them was stuck from a "light" fall earlier in the day, while the camera was in the case). I firmly banged the camera in the palm of my hand 3 times on 2 sides... The problem's gone and the pictures are no longer rotating.
Jan 28, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Belkin Dongle
You have to make sure first that the working pc is getting its internet connection from the BELKIN and not from the modem. To check that, right click the computer icon at the butoom right of your screen, click detail. ip address that is ok is in this form 192.168.xx.xx. If you are getting like 74.xx.xx.xx, that means that you are getting connection from the modem. THE MODEM ONLY GIVES ONE CONNECTION, MEANING THE ROUTER IS NOT FUNCTIONING CORRECTLY. After doing this you can give a follow up question.
Jan 19, 2008 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Computers & Internet Logo
47 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
