Looking for instruction manual for Hiseer split wall unit model number WMMS-18E-32B
3 Suggested Answers
hotuna
  • 288 Answers
SOURCE: carrier multi hi wall split a/c
I don't have a diagram, but maybe I can help you. You have 2 compressors, o.k. 2 stage system. A single phase contactor? do you mean a single pole, one side breaks, the other is always hot? Speaking of phases, is this a commercial unit with 3 phase? Also, Each compressor needs a separate contactor to carry the load. What is the question?
Posted on Dec 23, 2007
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
My Carrier mid wall split runs for 5 min on heating then it stops and then the green power led flaches 6 times
I'm no expert on mini splits but I do have one and I'm not sure if you're aware of this but the heating mode doesn't function if the temperature drops below a certain point. Look in your manual or do a search on line for your exact model number and you'll find the exact specifications.
Jun 10, 2014 | Office Equipment & Supplies
How to remove starck shower pole from wall
The first thing to do would be to identify the unit in question. If you have a model number we can provide the instruction manual for the wall bar. If no model number you can call me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'll be happy to help you identify the unit and provide instructions on the unit.
Dec 12, 2012 | Hansgrohe Axor Hansgrohe Starck Shower...
I would like to purchase the dough hook for my Braun mixer - Model No. KM 32B. It is an old machine but still works very well. If available I could have the hook sent to an address in the UK
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 09, 2011 | Microwave Ovens
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
I need instructions for an old glow worm programmer
If you have the model number of the unit you should be able to get a manual off of the manufacturer's ( who is now out of business) website. The website is www.desatech.com then you would click on Wall Heaters and go down to your model number and the manual will come up. If that doesn't work try calling Master Parts, they have a lot of the manuals. 800.446.1446. I hope this helps!
Mar 18, 2010 | Heating & Cooling
Hello im trying to trouble shoot two split systems the electrical wires were crossed for the two units I fixed it the compressors wont come on, wall unit says e7? This is on the Amcoraire ac split systems.
E7 indicates an "External Feedback Problem" which sounds like a communication problem. I believe there is a sensor cable that runs from the outdoor unit to the indoor unit also. Check that all cables are properly run to the appropriate unit and check all connections for tightness. Here is the link to a manual that includes installation and wiring instructions.
http://www.acwholesalers.com/EasyEditor/assets/amcor%20duo%20uchw-h12%20owners%20manual.pdf
Mar 16, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I HAVE A SPLIT ROOM AIR CONDITIONER, OLDER STILL PACKED BUT WITHOUT MANUALS. THE LABEL GIVES MODEL NO: AG0AH09BWOG1 , SEARCHES DONĀ“T GIVE RESULTS. CHEERS
The number may indicate its a 9000 btu ac/heat pump,just by knowing other types of ac Numbering is it 2 pieces IE;
the outdor condensing unit and a wall mounted evap.do you see a refrigerant line set ,are there connection points for refrig lines etc.
dan
Mar 02, 2009 | GE Heating & Cooling
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
