Question about Microsoft Xbox 360 Console
The console starts up fine everthing runs fine apart from the disk drive. I have taken apart the disk drive and put it back together, tried cleaning the lens and rails, all that happens is the disk sins up for 5 turns and then stops. I did the tweak not sure what to the laser, wherre it turns the power up? Now the laser does not light up? The disk however still attempts to spin up. Does theis mean the drive is bricked and cannot be fixed?
  • 839 Answers
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console....
click here to download repair guide
Posted on Dec 29, 2010
I start it up and then it goes strait to the browser/ system configuration
It is not recognizing the game disc. Try cleaning the disc and the disc drive.
To clean the disc, you can use water with a bit of dish soap if it is dirty. If it is scratched, you can try using a bit of car polish (apply, let dry and buff clean). Wash with water and dry completely before putting it back in the PS2.
Or try a disc you never use (e.g. Grand Tourismo).
To clean the disk drive, you can spray some "canned air" into it to see if you can knock the dust away from the laser/reader. DO NOT turn the can upside down when you spray. You will get liquid propellent inside the PS2 and that gets VERY cold when it evaporates. so cold that any humidity in the air will condense in your PS2 and it will surely not work for a while (even if you clean the disk).
If you are really adventurous, you can take the feet off the PS2 and then remove the screws and open everything up to do a good cleaning (it probably needs it - PS2 can be almost 10 years old!). Dont be afraid to take it apart - just use a digital camera to photo every step so you know how to put it back together.
good luck. Please rate me.
May 05, 2011 | Sony PlayStation 2 (PS2) Console
Do i fix the tray that wont open on my xbox 360
Either you have something sticky spilled on your unit, or you may have to replace the motor for the disc tray. Also take note if the tray is even attempting to open at all. If so, it might just need to be cleaned.
Oct 01, 2009 | Microsoft Xbox 360 Console
Disk stuck in tray and start up screen displays multiple languages and says box requires service
replace the dvd drive or take apart the dvd drive and take the disk out that wayto take it the console apart remove the feet and there are screws under them and two und the stickers toward the middle.case pops off upward,two scres next to controller port 1 and 2. small screw on harddrive bay.take the dvd drive off casing and dismantle.take the disk out and put the connectors back in.test it with the same disk if not shattered.it works put the system back together if not leave it apart so that ou can replace the drive later.if you got anymore questions feel free to emal me at gamecrazy944@yahoo.com
Jul 15, 2009 | Microsoft Xbox Console
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
My console wont read my disk
I had this same problem and i fixed it sucessfully. If your warrenty is still good obviously send it in and get a free new one. If that is not a choice this is what you gota do:
The problem may be one of two things:
First, many people had some magnet fly off their dvd drive, while your doing this repair and you notice some black thing stuck to the top of your DVD drive when you take the DVD drive apart, go on youtube and look how to fix it from there.
If not follow my instructions...if you don't know how to do a certain step, again search it on youtube there are many videos on how to do all of this stuff.
1. Take apart your 360 but leave the motherboard in the metal case (no need to remove it or unscrew all the screws)
2. Remove the DVD drive.
3. Open the DVD drive taking both metal panels off.
4. This is tricky. You need to remove the motor, there are 3 tiny screws, you can disconnect the little cable if you like but i wouldn't recommend it because it is very fragile.
NOTE! TWO OF THESE SCREWS ARE SPRING LOADED AND CONTROL THE HEIGHT THAT THE DISC IS TO THE LASER. MARK THEM WITH A MARKER ON THE SCREW AND RIGHT NEXT TO IT SO YOU CAN LINE IT UP WHEN YOUR PUTTING IT BACK TOGETHER, OR YOUR GOING TO SPEND HOURS TRYING TO GUESS THE RIGHT HEIGHT! COUNT THE NUMBER OF TURNS IT TAKES TO GET IT OFF THIS IS IMPORANT DO NOT OVERLOOK THIS! THE WRONG HEIGHT WILL MAKE THE LASER NOT READ YOUR DISC!
5. Take apart the motor by simply pulling the top off, many people seem to have trouble with this but it just pops off with a little twisting.
6. Get a Q-Tip and remove all that black gunk you see untill its spankin clean.
7. You gona need some lube. I used some gun metal lube whatever works, some had sucess with WD-40 but i don't recommend it. Lube that ****** up and put the motor back together.
8. Put the motor back in and screw in the 3 screws being sure to get the spring loaded ones the right tightness.
9. Piece of cake, put the DVD drive all the way back together (this is important) and connect the wires and place it back in the 360.
10. Plug everything in and try a game before putting the god forsaken case back together.
11. If it works, congradulations, if it doesn't, you got the height wrong.
12. Put everything back together, play some xbox. You deserve it.
IF HEIGHT IS WRONG: take the dvd drive out and panels off again and tighten or losen the spring loaded screws a tiny bit. Go in increments of 90 degrees, this took me hours but i finally got it.
IMPORTANT NOTE: THE DVD METAL CASEING MUST BE ON TO TRY A GAME!!! I DON'T KNOW WHY BUT IT WONT WORK UNLESS ITS ON.
Mar 18, 2009 | Microsoft Xbox 360 Console
My xbox wont read my game disc
if you can't send the xbox back to Microsoft this worked for me.
The 360 would spin the game up and say reading but than stop and do nothing.
I took the case apart, took out the cd drive, took that apart so i could get to the laser.
put a little big of very clean water on a q-tip, wipe the laser lens down and use the dry side to dry it off.  put it somewhat back together and test, this worked fine for me, it read a disk no problem.
Feb 21, 2009 | Microsoft Xbox 360 Console
PS2 Power problem
Check the power supply.Use a multimeter if you have any voltage coming out from the power supply.
If the power supply is good Check the main fuse on the motherboard.There is a white ceramic fuse on the motherboard and sometimes get Bad.
Good Luck
Jun 05, 2008 | Sony PlayStation 2 Slimline Console
Cdrom won't spin
HI THIS PROBLEM IS USUALY CAUSED WHEN LID IS PUT BACK ON .. THERE IS SOME LITTLE SWITCHERS ON THE PS2 NEAR THE LASER THESE SWITCHERS ARE TO TELL PS2 WHEN LID AS BEEN OPENED AND A ANTI PIRACY PROTECTION FOR DISK SWOPPING PICS SHOW WERE THE LITTLE SWITCHERS ARE ..__TRY TAKING THE LID BACK OFF AND PLACING LID BACK ON WITH LID TRAY SHUT AND IF THAT DOES NOT WORK CLOSE WITH LID OPEN AND AT THE FRONT WERE YOU PRESS THE BUTTON TO TURN POWER ON CHECK IF THE LITTLE SWITCH AS COME AWAY OR BROKE IF SO I SELL REPLACMENTS MY WEBSITE IS WWW.CONSOLEREPAIRANDPLAY.CO.UK
May 23, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
