Bush AK37 32" screen old style TV , 6years old. Screen looking pinkish. All whites show as pink, as if one of the 3 colours is missing.
    Sergeant:
    Champion:
  • 230 Answers
I think its time to change the components of your tv,as it is 6 years old.The problem may be due to the picture tube or due to the fault in the output transistor ,check both and proceed .Better give the tv for service
Posted on Jul 07, 2008
    Genius:
  • 3,422 Answers
Possible bad output transistor (red/green/blue) or other component in the screen circuit or the picture tube itself could have an element shorting to ground inside the tube. You will also notice diagonal lines with this.
Good luck
  • Priya darshan Jul 07, 2008
    You need some capacitors replaced. They dry out over the years and can no
    longer function correctly. Take it to a TV repair shop and they should
    be able to get it working fine again.
  • 2,323 Answers
I would suggest to adjust the tint to about 50% first. If that does not work, there could be dry solder joints on the video amplifier board that is connected to the CRT.
  • 19,396 Answers
The rgb board is faulty
  • Ginko
    Ginko Jul 07, 2008
    The rgb board inside tv is faulty and is starting to give problems, a repairman can fix it testing and eventually replacing blown component (often a capacitor) on rgb board or replacing the whole board.
Why does my galaxy s3 screen turn black, green, or pink?
Screen colours are "additive".
They take some amount of each of the 3 "primary" colours, to make a specific colour. For example, 100% + 100% + 100% gives "white". Getting "pink" when you expect "white" means that you are getting 0% instead of 100% of one of the 3 colours.
Bad screen, or partially-broken cable between the "motherboard" and the screen.
Feb 09, 2015 | Cell Phones
My Bush 24" TV is only showing a white screen !
Check the video output voltage to CRT board. It might be absend.
Apr 26, 2012 | Bush Televison & Video
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Pink colour
Hi there!
May be that the colour Amp is at fault or the tube is busy failing. Commonly it would be the colour Amp (Dry joints or faulty drivers). The Green is dead. I have had cases where power surge can magnetise the tube to such an extend that the whole picture will show one colour. In your case I doubt it very much. Good Luck,JUS004
Feb 26, 2008 | Bush WS6671 28" TV
53HX71 showing lots of green
im thinking blue lamp if whites look pink thats telling me theres not enough blue.
Dec 05, 2007 | Toshiba 53HX71 53" Rear Projection...
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
