Question about Cycling
The rear wheel is in free spin in both directions,
  • 843 Answers
If the problem is that the wheel can spin silently in either direction (without the normal ticking sound when it spins forward) then the problem is that the ratchet pawl(s) are either broken, or stuck. You might get lucky and can free it by spraying WD40 into the the freewheel. If that doesn't work you'll have to replace the freewheel.
Posted on Dec 29, 2010
How to set rear brakes
If they are rear drum, after removing rear drum and finding adjustment wheel........put drum back on and adjust wheel out until drum is unable to spin because the shoes are out, then screw back in until it spins free and then do other side.
May 03, 2016 | Cars & Trucks
2009 xt forester grinding noise when engaging clutch and stalling
Are all 4 tires and wheels the same size??? (will bind the driveline up)
You could have a bad differential or transfer case.
Jack up all 4 wheels, spin one rear wheel with it in gear, the other should spin in the opposite direction, do the same for the front. If they spin OK, take it out of gear, now spin BOTH rear wheels, if they won't, you might have a bad transfer case.
May 22, 2014 | 2004 Subaru Forester
Truck will only drive in 4wd, no power to rear wheels
I would guess your differential. Raise your rear end and try rotating wheel, it should make the other wheel spin the opposite direction. I'd the other wheel doesn't spin, I would say it's your differential.
Apr 14, 2013 | 2000 Chevrolet Silverado 1500
Trouble with ABS Brakes system on 2001 Chrysler T&C Jerks real ibad in rear while driving
I do not think this is an abs problem but rather a out of round drum, this problem only happens when you are braking ? if this is the case then i would check the rear brakes.
First make sure the rear wheels are spinning freely, if you use the e-brake then make sure there is not a cable holding.i bad e-brake cable will sometimes not release the wheel or both rear wheels causing the brakes to stay on in the rear, they may not be on all the way but on to cause the rear drums to over heat and get out of round causing a bad pulsating when braking.
Jack up the rear of the car and make sure the wheels are free spinning, if they are not then you will need to find out if its a cable, bad adjustment or frozen wheel cylinder. If the wheels spin free then have some one step on the brake and see if wheels lock up then release the brake and make sure they spin. next is to do the same with the e-brake.If all is good then replace drums or see if they can be cut. The last thing would be if the wheels are free and the car shakes when driving along and not braking then you may have a bad tire or bent rim. good day.
Apr 29, 2012 | 2001 Chrysler Town & Country
Truck sat for about a year and now when in park rear wheels both spin freely. When in gear pinion and ring gear do not seem to engage but wheels spin freely without making driveshaft spin. Is this in the...
Hi, well with both wheels off ground, they will turn opposite directions when you turn one of the wheels even in park. now if engine is running and you put it into gear and the driveshaft turns but not the wheels, then someone stole the guts out of your rear end.
Aug 10, 2010 | Chevrolet S 10 Cars & Trucks
Rear wheel will not rotate after spinning on snow/ice
rock the car to brake them free the brakes are locked up
Feb 11, 2010 | Buick LeSabre Cars & Trucks
Shaft coming out of transmission that clutch basket slide upon..it this suppose to free wheel while transmission is in gear...please help this is on a big dog k-9 motorcycle..6 speed baker transmission
Without clutch plates installed. The clutch basket inner is directly connected to the tranny input shaft- if you turn the inner clutch basket while in gear it should drive the rear wheel. The outer basket should spin freely regardless of gear selection and have no affect on the tranny.
The input shaft of the tranny itself ( the shaft the clutch basket slides on) should not free wheel when in gear.
Dec 06, 2009 | 2001 Titan Gecko RM
2001 tt when the steering wheel is turned all the way in either
HI IT SOUNDS LIKE YOUR HALDEX CONTROL UNIT IN THE REAR DIFF HAS FAILED AND WILL HAVE TO BE REPLACED,ANDY.
Mar 19, 2009 | 2001 Audi TT
Possible rear wheel problem
if both rear wheels are off the ground, yes. note that they turn in opposite directions.
Jan 03, 2009 | 2004 Chevrolet TrailBlazer
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
