I have a Tappon furnace DGUF 106 02 EF Serial 77D18453 The unit has an intermittent problem, It will cycle at will, thermostat is good I can sometimes get it to come on by heating the unit above the control valve(the one with the spark plug wire looking wire from the bottom) OR cycling the main valve removing the Yellow wire several times. this is not working well now . any Ideas?? Thanks Ted
  • 770 Answers
SOURCE: Room AC, reverse cycle..heat does not work.
if it is a Heat pump style the rev valve is in the Freon lines you will have to pull the unit out into the room out of it's sleeve which will stay in the wall rev the flow of refrigerant is it cooling ok?? there is a solenoid on that valve that may be bad i would check that first you will have to look to see if it is energized in the heat or cool mode first to make sure it is switching it should look like a sideways tube with 3 outlets on one side and 1 inlet on the top and the solenoid coil as well with 2 wires going to it let me know what you find out ...1 Note the unit may have electric heat and the element maybe out you will have to pull to check
Posted on Jan 24, 2008
  • 104 Answers
SOURCE: Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Posted on Jun 18, 2008
  • 3361 Answers
SOURCE: I have a Consolidated Industries gas furnace,
The digital thermostat must be programmed for GAS heat.
If the problem occured before the t-stat change and is still happening, the problem would be with ignition within the furnace.
Posted on Mar 15, 2009
  • 16 Answers
SOURCE: Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Posted on Apr 07, 2009
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
We are having an issue with our furnace. It reaches temperature, clicks off, clicks back on, clicks off. It happens intermittently. We can't tell if the problem in with the furnace or the thermostat.
An intermittent problem can take patience and time. Process of elimination too. If you are unfamiliar with servicing and repairing a gas furnace, you may want to leave that chore to a professional. Now, what exactly is coming back on after the set temp is reached? Blower only or is it firing the furnace also. My experience says it's just the blower. This is caused by... Furnace overheating, then shutting down, then bringing blower on to cool it down. Probably not your scenario. It's possible the control board is acting up. Highly possible that you have a high temp limit with a loose connection, or needs to be replaced. Schematic will call it HS or LS, something like that and it should have 2-6 of em. Possible that the G wire from the t-stat is shorting to R, and bringing the fan on. Try posting more info? Model & serial number. Fan cycling or furnace? Have you checked new t-stat installer configuration? Hope this helps! And work safe
Oct 31, 2017 | Heating & Cooling
Furnace start stop cycle
On properly sized furnaces there are a few controls to look at. Check the settings of the fan switch. If these are unchanged then there may be a reason the furnace is shutting off due to poor air flow and resulting high temperature. Check filter and verify air flow is good. It may be possible that a safety switch is failing and intermittently on and off. Are all the covers securely in place and hitting any safety switches? If not seated properly the cover may loosen when the fan runs and the switch shut off the unit. There is often a flame roll out switch that could have been strained. Lastly, has the thermostat been working long? Thermostats have internal heaters to stop the furnace which is called a heating anticipator. If the thermostat is near a heat source (heat duct, refrigerator, oven, person, hot water pipe), worn out, anticipator is set wrong (older electric thermostats have adjustable settings) or covered (yes, I have seen some covered) then the free room air cannot measure correctly and the thermostat cannot control what it cannot accurately measure. Of all these possibilities I would start with the thermostat and proper furnace air flow, second check the fan/high limit switch and third go component by component through the wiring diagram looking for defects in each component. If available follow the manufacturer's troubleshooting guide.
Jan 11, 2014 | Rheem Heating & Cooling
I have installed a new Honeywell CT87 non-mercury manual thermostat. It runs but the the furnace turns off the room temperature alway at or beloe the furnace setting so the furnace turns back on again and...
Hi, these mechanical thermostats have what is called a heat antcipator on them. If you remove the cover you will see in increments or numbers such as 1.0, o.1, .2, .3, .4 or o.1, 2, 3, 4, . The stat and main gas valve work together and have to draw the same amount of amps to cycle the unit properly. This stat will have a copper arrow pointing at a number. A good place to start is to set it at .4. If the unit does not cycle right, set it at 1.0 and go from there until it cycles. Let it go through several full cycles during each time you adjust it until it is correct. These are good dependable stats as I have many on my service truck. If it doesn't take care of the problem, take it back and return it for one that is not faulty which happens often. Best of luck to you.
Ps, the small manual that comes with a new stat has that information on it, anticipator settings.
A/C, & Heating Contractor
Mar 11, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I just got a new Honeywell Utility Pro Thermostat. The digital temperature gauge seems very sensitive which results in the unit turning the furnace on and off for very short periods; much shorter than my...
Sounds like you also have a high efficiency furnace like mine.
Here is a procedure to slow down the number of cycles you are experiencing.
1. press System
2. press and hold buttons 3 and 5 on the bottom of the screen. (there should be 7 buttons displayed)
3. set code to 240
4. change setting to 3 for 3 cycles per hour. (your thermostat probably shows a higher number, probably 5? That is why your unit is cycling so often).
Jan 20, 2011 | Honeywell Electronic Programmable...
Even in manual operation the heater come on intermittently and the temperature does not increase. Hi, here is a site for you to go to that will show you a video on how to solve your problem. I can walk you through the same process, but here you will have pictures of the flame sensor which is your problem if you have this type of furnace. If you have something that is much different, you need to give me the model and serial numbers and type of unit you have. If you do have this type of furnace you can see what happens when the heater goes of intermittently. This is a very short video. Please keep me posted. Get back to me.
Mar 21, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programmable thermostat with a York high efficiency furnace. To turn the heat on, the thermostat "clicks" and cycles the furnace through startup (warm the fire starter, turn on gas,...
Well, it is a computer, and they all glitch, now & then, you say it clears with a power off, and thus resets it, It maybe a thermostat, flaking out, they do that, but the 6'o'clock, thing being the "Or" that sets it apart, I wonder if it isn't just a faulty control unit, as two together is too many, for a single cause, now, it sort of points there, but also, may sound silly but first, of there is any, Check your backup battery..
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
Gas furnace is constantly blowing cold air
An indoor blower running when it is not supposed to usually indicates an overheat condition. I would guess that it has been cycling on and off for some time and finally caused the high limit to stick and not auto reset. if you tap it sometimes they reset. the real problem is that it has been overheating from lack of airflow, over sized unit, not enough return air, too many closed registers, dirty filter, dirty squirrel cage blower and or air conditioner a-coil. If you get it started again sit and watch the unit run the flames should come on and stay on for the entire heating cycle, not going on and off.
I wish I could help you more but it is difficult without seeing the problem myself. Good luck! this should get you started!
Nov 01, 2009 | Heating & Cooling
Nordyne LP Furnace wont fire
might be the flame sensor need replacing.
Apr 15, 2009 | Kitchen Appliances - Others
Ruud heater will not light consistently
Your furnace is going into a lockout condition, cycling the power resets the circuit board and it starts over. I will need to know approximate age and model of your furnace, it sounds like you have need to clean the flame sensor rod. However i need to know what i am working with.
Dec 18, 2008 | Ruud UBHC Air Conditioner
Intertherm gas furnace
Need more info. Are you saying that when tstat calls for heat then it short cycles. But if you turn it off then back on it runs ok?
Mar 21, 2008 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
