Question about Vacuums
The handles on my Rival crockpot Type SC6 Model#SCV601 broke off. Is there a recall on these? If not there should be.
White Wing Steamer II. What has caused it to fail?
if it is new or within the warranty period then take it back for a warranty repair
the wires are dangerous and should only be attended to by an appliance repair shop. contact the manufacturer and report the problem to their engineering section or customer service as there may be a recall out or a modification that is available,
Aug 30, 2015 | Vacuums
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I need a lid (cover) replacement for my rival slow cooker model scv551. The plastic lifting piece has cracked.
I need a replacement cover for my Rival Slow Cooker size 3.5 quart Model 3730. Where can I get it?
Feb 06, 2011 | Vacuums
The handle on my h2o steam mop broke. Where can I find a new handle?
we have no resources to find parts, sorry if u didn't understand that, that said based on my experience you will not be able to buy parts for this, this type of product is considered "throw away"
Sep 09, 2010 | Vacuums
Shark model V1700Z The handle broke off at the
Look it up online. I found a place that charges 7.95 for the part & 6.99 shipping. Get the Model # off the bottom. Mine is V1700Z. And look it up that way on Google or Bing. I think it's listed online as EuroPro.
My servers love this little baby, but they keep breaking that little piece. I understand that the rechargible batteries may wear out in a year, but I have yet to have a handle base last that long.
A Bissel sweeper costs more, clogs faster & does not do as nice of a job. so even if I have to replace it 2x a year, it's not a total, loss
Jul 14, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Sep 23, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Handle broke off when Vacuuming?
Two screws hold that handle onto the machine. Maybe they weren't installed when the machine was put together.
If it broke part of the dust compartment, it's probably not worth fixing.
If it broke part of the handle you can order a new one for about $30.00. It's part #75765-2.
Dec 01, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover Wind Tunnel U6439-900
There was a recall from Hoover awhile back regarding the switch, On the model number tag is an 1-800 #, call it and have your model and serial number ready, they will tell you if you need repair from this recall. But if it is only 2 or 3 years old, then it isn't for your model. Otherwise just replace the switch.
Dec 24, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
