Question about HP Photosmart 7450 InkJet Printer
Carridge jams to the right, paper feeds approximately 3" then also jams. Red light blinks. Any ideas?
  • CPCI
    CPCI Dec 29, 2010
    hi
    is it Q3409, 10, 11 or Q3412 ? -- look on rear or back of unit to clarify exact HP part #
  • Anonymous Dec 29, 2010
    Q3409A
    Thanks
    Genius:
  • HP Expert
  • 1,325 Answers
Hello there --
go to this link and follow instructions carefully and completely
if this persist, you will have to contact HP directly,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00840472&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=397785
Solution six: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , fees might apply for contacting HP.
Posted on Dec 29, 2010
When i turn my ofice jet 4110 on, rhe yelow light comes on for approximately -3 seconds and is immediately replaced by the flashing red light which stays on no mattr what i try.
There are usually 2 culprits for this. Try these first and they might solve your problem.
1. ink cartridge jam - sometimes the ink cartridge is loose. just remove it and put it back.
2. paper jam (or other stuff) - sometimes some paper/paper clip/ rubber band gets jammed in the paper feed
Try also looking at the PC/laptop which it is connected to. There is a chance that a message will show the actual printer problem.
May 18, 2011 | HP Officejet 4110 All-In-One InkJet...
Paper red light blinking. paper is full. What could be wrong? Will not print
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Jun 12, 2010 | Brother HL-2070N Laser Printer
Paper dosnt feed in printer pixma mp210 photo. HELP
Either paper jammed, stuck by foreign object or DRIVE ASSY faulty.
May 25, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Red "Paper" light stays on; printer will not print.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Red light stays on, but nothing moving after clearing paper jam
About the last post, I must also add that the main clue that led me to that conclusion, was the fact that, when I first turned the printer on, THE FAN BEGAN to rotate. Hence, I thought, all the other aspects were right, but somewhere there might be a mechanical "jamming" that stops either the fan or other part to move and obstacles the cylinders or gears from moving, hence sending the printer a signal of jamming. I had looked for the "messages" from the printer, and the diagnosis for our problem (red light in the online error, and green light in Toner Save) was that either there was no ink or no cartridge, no paper, or paper jamming (please post if there was other cause for this diagnosis). I discarded the other grounds, so the unique left was that the printer thought was that there was a paper jamming. This lead to the fix I described in my previous post.
Regards,
David López Salgado
Bogotá, Colombia
May 02, 2009 | Samsung ML 2010 Laser Printer
Hi, I'm Ron a Disabled Frustated Senior Citizen. I have or the AX is going to get it. HP Photosmart 8050. 1, ONE Peice of paper Jamed. Now the RED Light is Blinking? No Idea. Also it says Print Cartridge...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck..
Dec 30, 2008 | Office Equipment & Supplies
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Won't feed the paper
the problem with your machine maybe that the default paper size programmed into your machine. My guess is that it is set to legal size{ 81/2x14} Get your owners manual out and see how to program the paper size in the user settings sections.
Jan 18, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
HP Photosmart 7450 InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
