Question about Sony KP-51WS500 51" Rear Projection Television
Sony Kp51ws500 Jumping Colors
I have a sony kp51ws500 and it is giving me an error code 5, and the picture is 'jumping' It displays images and jumps even when not hooked up to a video source. The Red is most pronounced, but I think the others are doing the same. The color is off by a measure and jumping back and forth like color static. I didn't see other posts similiar to this. I was wondering if it could be either the Convergence amp, ICS, or if I should replace the whole board.
Thanks in advance!
    Genius:
  • 2,920 Answers
You will want to replace the whole board
Posted on Nov 04, 2008
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Sony Audio Players & Recorders
Powers on then right back of light flashes 8 times
Looks like a problem on the convergence board which requires repairing/replacing..
Oct 30, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony fd trinitron wega kv34hs510
The set may have a self check mode or error buffer--most of these that do with the set turned off: Display, 5, vol. down and then power.
If it has the buffer a box will appear in middle of screen with several items listed-----------all should have a 0 to the right of them---a number indicates a error detected and noted.
If no error found or no display for that contact Sony for the reset code which usually is gained by going into tech menu (different from error menu) and with remote pressing 7 and enter---this does a hard reset and returns set to all factory defaults--if that did not cure it you have a interesting trouble...........
Mar 19, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
SONYmodel # KP51WS500 tv work for 45 minutes then blankout with a blanking red light
How many times does the light blink in between pauses? Let me know and I will assist the blinking is an error code.
Aug 09, 2011 | Sony KP-51WS500 51" Rear Projection...
Kp51ws500 Tv has double outlined colors pink and green. Tried to adjust with the flash focus and nothing happens. Is there anything else we can do. What is a hard start?
You will need to install the sony type 1 convergence repair kit which fits your model. Its available from www.tvrepairworld.com and contains the parts and the CD with repair instructions.
Jun 21, 2011 | Sony Televison & Video
MY SONY KP51WS500 HAS 6 BLINKING LIGHTS AND WILL NOT COME ON...
the set has detected and error of missing a voltage of 5 volts
Oct 15, 2010 | Sony KP-51WS500 51" Rear Projection...
How to jump diagnostic on comp 95 buick lesaber
refer to the image bleow for jumper points to draw codes.
Sep 03, 2010 | 1995 Buick LeSabre
I have a Sony kp51ws500 convergence problem
Required convergence repair kit for Sony KP_51WS500 is available HERE, click for more info.
Thanks.
May 21, 2010 | Sony KP-51WS500 51" Rear Projection...
Have sony kp51ws500 won't turn on, it clicks then shuts down and i get 7 blinks on front--had green, blue, and red line issues before
Hi wright
To answer your question;
The 7 blinks code(sony error codes) means that the horizontal deflection has stopped.
The common cause for this are transistors Q8035,Q8038 and the horizontal output Q8024 all located on "D" board.
Hope this help and let me know if you need further assistance.
Feb 18, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
168 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
