Question about Whirlpool ACP102PS Portable Air Conditioner
ERROR HO EN AIRE ACONDICIONADO WHIRPOOL PORTATIL
Aire acondicionado
I can't understand this language. If you are in search for a remote code, visit this link. http://electrohelponline.blogspot.com/ It has setup codes to so many brand remote controls.
May 13, 2013 | Cars & Trucks
El fusible de aire acondicionado
En donde esta el fusible para el aire acondicionado,, nitro 2007
Apr 20, 2013 | 2007 Dodge Nitro SLT
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
Para un mitsubishi endevor 2005,la salida del agua
The water is clear condensate water from the air conditioner evaporator drain. You'll notice that the water doesn't contain any antifreeze or odor. Keep in mind that running with the ventilation control selector in the defrost position also runs the air conditioner. The foam seal around the drain tube and the fire wall has deteriorated allowing water that is blown back against the fire wall around the drain tube to enter the passenger area of the vehicle. You can see the hard plastic drain tube protruding low on the engine side of the fire wall. It's about an inch or so long and a little better than a half inch in diameter. The fix is easy and permanent. Cut a 2.5' patch from some rubber gasket material, it can be round or square doesn't matter. Cut a round hole in the center of the patch that is slightly smaller than the tube. Slather one side of the patch with marine sealant and slide itover the tube with the sealant side tward the fire wall pressing the patch against the firewall. Now use a wet dry vac to extract as much of the water from the passenger foot well as possible an wait about a week or so for the carpet and padding to dry.
Feb 25, 2010 | 2004 Mitsubishi Endeavor
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
El aire acondicionado de mi trailblazer 03 no funciona en las ventanitas de enfrente solo en las de abajo para los pies...cual puede ser el problema?
El vacío se utiliza para cambiar el flujo de aire a los respiraderos. Suena como usted tienen una manguera de vacío floja o disconnected en el lado trasero de los controles.
Jul 22, 2009 | 2006 Chevrolet Trailblazer Ext
No arranca el compresor y dispara el breaker
Cuando un compresor de motor ha sellado "quemado", esto significa que el cableado del interior del motor se ha convertido en irreparablemente dañado: el compresor del motor devanados puede quemarse y en corto o en corto junto con la cáscara de acero del motor, o pueden tener las bobinas quemadas y simplemente ser "abierto" o desconectado. Si el motor se ha quemado en cualquiera de estas formas tiene que ser reemplazado.
Cuando un compresor de aire acondicionado ha "quemado" por el cortocircuito de los componentes internos - que no se inicie en absoluto. Este fallo es detectado por el poder y desconectar todos los cables de la unidad y la medición de la resistencia (ohmios) entre el motor de arranque / común y ejecute / terminales comunes. Si hay resistencia a cero el bobinado está abierto o roto.
Si la resistencia medida a través de un compresor y su liquidación aguja del medidor está atascado en en el infinito, o "OC" / "OVER" sobre un metro digital, que indique el compresor bobinado está abierto (a través de quemado). El mismo efecto se puede observar a partir de una simple conexión del medidor a absolutamente nada.
Si la resistencia medida a través del bobinado del compresor de aire acondicionado está demasiado cerca de 0 ohmios, es corto. El compresor debe soplar el fusible o el disyuntor viaje cuando el poder se vuelve a encender. Pero ten cuidado: tenemos los informes de campo de los equipos de grabación e incluso incendios ups cuando el interruptor del aire acondicionado para el compresor pasa a ser un viejo FPE de Stab-Lok Zinsco o unidad.
Si hay resistencia entre el motor y la terminal de la carcasa de motor, el motor se ha convertido en cortocircuito a tierra la unidad interna y necesita ser reemplazado. Si no hay resistencia entre la creación y la gestión de las terminales a las comunes, pero hay resistencia entre la creación y la gestión de terminales, esto significa que el motor interno de protección contra sobrecarga del circuito está abierto. En este último caso, permitir que se enfríe el motor y la repetición de la prueba antes de que lo sustituya. Dime si esta ayuda, Gracias, Sea Breeze
Feb 04, 2009 | Heating & Cooling
Aire acondicionado
tengo problemas con mi aire acondicionado ..al cambiar el filtro...solo tira aire caliente no enfria en lo absoluto
Jul 06, 2008 | 1994 Toyota Land Cruiser
Whirlpool ACP102PS Portable Air Conditioner Logo
157 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
