Question about Hansgrohe Replacement White Head Toilet Brush 40088000
Trying to buy 2 replacement heads for my hansgrohe toilet brushes in interactiv pattern
    Genius:
  • 1,739 Answers
Your part is listed on the USA site; authorized on-line retailers are listed here:
http://www.hansgrohe-usa.com/us_en/131332.htm
If you are not in the USA, you may want to check if Hansgrohe has a website in your country:
http://www.hansgrohe-usa.com/us_en/19254.htm
Trust this is helpful.
Posted on Dec 29, 2010
How do you remove the Metris S wideset faucet handle?
To remove the handle simply rotate the escutcheon counter clockwise and it will unthread from the fixation on top of the counter. Then the handle will lift off as one unit. You can clean them with CLR to clear up water deposits. If you need further instructions feel free to contact me Hansgrohe Tech 1-800-334-0455 press 2 for Technical and ask for David Scarborough. I'll be happy to help.
Apr 08, 2013 | Hansgrohe 31063821 Brushed Nickel Metris S...
How to install hansgrohe toilet brush
This model has a bracket that will mount to the wall using two screws and plastic anchors. Then the brush holder will snap into place on this bracket. There will be a hole in the bottom of the holder that will look like a set screw but this is only a push pin. It is spring activated and not threaded. To remove it you simply push up on this pin and pull the holer off the wall bracket. If you need further help feel free to contact Hansgrohe Tech at 1-800-334-0455. Press 2 for Tech and Ask for David Scarborough. I'll be happy to help.
Nov 20, 2012 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
Need to replace cartridge on hansgrohe talis high arc faucet
The cartridge should come with instructions on replacement. The part number for the cartridge is 92730000. It is available through your local dealer or online dealer. If you need further help with obtaining the cartridge or installation feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to help.
Oct 04, 2012 | Hansgrohe 32070821 Talis S Single-Hole...
Hansgrohe clubmaster shower head is dripping
First step is usually just taking off the shower head and apply a descaling solution but make sure you read the intructions for which material it can work on eg brushed nickel.
May 15, 2012 | Hansgrohe 28496821 Clubmaster Shower Head...
I have a hansgrohe 06697865 Kitchen faucet with "Spayer" end That drips constantly Where can I buy a kit to repair, and how to manual?
You should contact your hansgrohe customer service hotline found on the installation book. They will help you solve the problem.
Aug 29, 2011 | Hansgrohe 32070821 Talis S Single-Hole...
Hansgrohe 41533 wall mounted soap dish install
I had the same problem with a Hansgrohe set screw on my toilet paper holder. Thought an allen wrench would do to open it but it does not work, I had to use the end of a pointy dinner knife to coax it out, might have also used a flat edge glass repair screwdriver also to get it out. It almost look as if it was "stripped" in the opening. I'm now trying to find a replacement set screw and came across this page. Hope that helps.
Apr 15, 2009 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
How to install Toilet Seat
Use a flat head screwdriver to pry open the plastic pieces that cover the screws. Using the same flat head screw driver, unscrew the large plastic screws holding the old seat in place. There are usually plastic nuts on the underside that you can hold on to while removing the screws. Remove the old seat. Clean the area where the screws were and dry thoroughly. If the new seat has an adhesive pad, remove the covering from the adhesive and put the seat in place. Thread the new screws through the holes and attach with the new nuts. If there aren't new nuts and screws, you can use the old ones, provided they weren't damaged during removal. Snap the caps covering the screws on the new seat in place. Be careful not to over tighten the screws! Since they're plastic, they can be easily damaged by a screwdriver!
Aug 27, 2008 | Hansgrohe E & S Accessories 40522000...
Hansgrohe Replacement White Head Toilet Brush 40088000 Logo
174 people viewed this question
Top Hansgrohe Home Experts
Shehu Pro
Shehu Pro
 John
John
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
