Question about Samsung CLP 300 Laser Printer
Light black print on the left side of the page.
    Problem Solver:
  • 6 Answers
Cartridge problem
Posted on Dec 29, 2010
Inky
  • 691 Answers
SOURCE: HP Color Laserjet 3500 printer - no black on left side of page
I would suggest you try replacing the dev unit itself. This should rectify the loss of density on the one side. If you need a service manual for assistance with changing the dev unit, try http://www.TheServiceManualShop.com they will likely have one. I presume you have also checked the laser lens to see there is no toner spilled onto it? This usually only accounts for thin areas of blank print.
Posted on Sep 29, 2007
checkitright
  • 1362 Answers
SOURCE: hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Posted on Nov 08, 2007
SOURCE: Black Toner Problem
I had the same problem with my 4 month old Samsung. All of a sudden i had a missing black stripe down the left hand side after replacing the cyan toner with a refilled one!! So.....i uninstalled all the old drivers and downloaded and installed the latest ones.... replaced the cyan with a new genuine toner....removed the black toner, shook to redistribute and put it back.....checked the imaging unit for actual visual damage (there wasnt any!)..... then printed off 50 or so black n white documents. Eventually the 'stripe' dissapeared.
The colour toners were fine all the way through!
It worked for me, hope this helps!
Nigel
Posted on Feb 20, 2008
  • 46 Answers
SOURCE: line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
Posted on Oct 16, 2009
  • 40 Answers
SOURCE: My hp 2420 is printing a black line-form
Lines are usually caused by the toner cartridge or the fuser. In order to determine the cause you can replace the toner and see if the lines go away. If not then it is in the fuser assembly and you would need to replace the fuser.
Posted on Nov 02, 2009
Why is it when using black it only comes out grey on the far right side
remove toner and drum unit
remove toner
check to see if there is toner in the drum unit if not fill unit run 5-10 prints
replace dev roller
replace drum cylinder(opc)
Jul 14, 2014 | OKI C5150n Led Printer
Hp 2600n printer printing light on the left side of the page
clean the scanner & calibrate the printer thre times ur problem will be resolved
Jun 03, 2010 | HP Color LaserJet 2600n Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Samsung CLP 300 Laser Printer Logo
35 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
