Question about Princeton Digital VL173 Monitor
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium 64-bit and the monitor will not display past the inital black screen with the four colored flags. Connected the monitor to an identical computer using a Core 2 Duo and the 32-bit verision of Windows XP Pro and the computer works fine. Is the problem 32-bit vs the 64-bit or is it Windows 7 vs Windows XP?
    Problem Solver:
  • 12 Answers
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Posted on Jun 25, 2011
I have an old dell dimension 4300, it is running windows xp. i havent got the system restore disk and when i try to do it through windows it wont let me. How else can i do it?
Well download a disc from here http://www.tipandtrick.net/2008/download-unmodified-original-windows-xp-with-sp3-integrated-full-retail-and-vl-install-cd-iso-image-from-msdntechnet-plus-via-http-or-torrent/ download which ever version came with your computer either home or pro, burn it using a iso burner, and viola' you're good to go on a reinstallation.
Sep 26, 2010 | Dell Dimension 4300 PC Desktop
Can Windows XP be installed on an old Toshiba
Hi, here is a link to the system requirements page at microsoft. It would suggest that it would work with your computer, but only just. As you see, your processor is right at the bottom end of what is required. I hope this helps! http://support.microsoft.com/kb/314865/en-us
Jul 20, 2010 | Toshiba Satellite 4000CDT Notebook
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
Monitor Problem
That is because your computer is trying to display a picture at a higher resolution than the monitor can handle
EG. if your monitor was only capable of lets say 800 x 600 and you decided to try force it to display 1680 x 1260 your monitor would do one of three things
try but die doing so
switch itself to sleep or standby mode
scream at you that its "OUT OF RANGE"
The H & V numbers are horizontal and vertical frequencies sometimes it is possible to use the monitors own OSD to change these but please check in the monitor manual before you do so.
Your best bet is to start your computer in safe mode and re-set the resolution to something a little more in the range of the monitor and then try re-boot.
If this information was useful then please click below
Aug 17, 2009 | Princeton Digital VL1916 19" LCD Monitor
Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
Oct 02, 2008 | Computers & Internet
ASUS EN7950 GT 512MB .. pROBLEM!
Hi, I think you will need to run the Dell restore disk, install the orriginal drivers and use the dell system to bootup then load the drivers the ASUS drivers then close the system, install the new card and then bootup. on doing this there will be resident drivers for the new card and it should work fine, then delete the orriginal drivers.
Regards mistyman
Oct 09, 2007 | ASUS EN7900GT/2DHT/256M GeForceĀ® 7900 GT,...
Computers & Internet Logo
346 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
