Question about Panasonic NN-S541 Microwave Oven
Our Microwave immediately blows the circuit breaker as soon as you hit the start button. It is a three year old Panasonic Inverter 1100W, model # NN-SA247S and it is plugged in to its own plug in which is wired direct to the box. It has worked fine and never missed a beat up until thisd point.
ukvacfan
  • 328 Answers
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Posted on Apr 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Hi, I have a NN-C784MF
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Posted on Jan 02, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: PANASONIC NN-SN789S MICROWAVE INVERTER. IN LOCKED
The owner's manual cover should cover this. if for some reason you don;t have yours, you should be able to download it here.
If you're outside the US, see Panasonic.net.
Posted on Jan 17, 2010
Panasonic microwave NNP295SF shuts off after 15 seconds
It is going to be one of three things, the magnetron, " heart of the microwave oven " the inverter board, " if 7 years or less" and finally the keypad control board. In order to break this down, it will require testing to narrow the field. But what ever choice is made, the parts and labour are going to be the big factor when it comes to cost.
Apr 18, 2012 | Panasonic 1.2cu ft Microwave- Black...
As soon as i try to cook anything it blows the breaker, its only 2 years old doesn't start cooking at all just as soon as you hit start the breaker blows my model is a nn-sd297 of course it's 2...
The service manual is here.
You can order parts from Encompass here.
It may be a bad monitor interlock / short switch, or possibly a shorted capacitor or other problem in the inverter.
But I'm surprised the 20A fuse is not blowing before the breaker is!
I hope it's on at least a 30A breaker...
Let me know if I can help further.
Sep 14, 2011 | Panasonic NN-P295SF Microwave Oven
HOW DO I UNLOCK THE panasonic dimension 4 Genius inverter NN-C20035
Its a child lock if your suffering with the same thing as us,My six year old brother managed to lock the microwave,all it displayed was a frustrating 'LOCK' message.to fix it i just hit the 'stop/reset' button three times
May 14, 2011 | Panasonic Microwave Ovens
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Feb 06, 2010 | Panasonic NNH965BF Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic Model NNS768BA Genius Premier 1100W Display works - nothing else comes up H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Sep 14, 2008 | Panasonic Microwave Ovens
Loud pop
You probably have a blown fuse (15A or 20A ceramic type) which may be caused by a blown part in the high voltage section. These are widely available at local stores. You can find exploded views and parts by entering your full model number here: http://www.geappliances.com/shop/prts/ If the new fuse blows immediately when you hit the START button, you also have a shorted high voltage capacitor. Need more help? http://www.fixya.com/ServiceRvw.aspx?advid=14&ctgid=153
Dec 15, 2006 | Kenmore 63652 Microwave Oven
Panasonic 1100W high power
It may have a blown fuse or - assuming yours is a model NN-H965 - a defective inverter. The fuse is generally located on the bottom of the chassis of the microwave. You have to remove the outer cover on a counter top model - or the front panel assembly on an over-the-range model. There are several reasons why it may blow. If the fuse is loose in the holder, the fuse and the holder should both be replaced. If - with the microwave disconnected from the wall - you can easily turn the fuse with your fingers while it's in the holder, then it's too loose. What happens is the loose connection generates too much heat, causing it to melt internally. If so, you'll usually see a ball of solder at a point where the cap meets the body of the fuse. If the fuse blows as soon as you plug the oven in the wall, or when you open the door, the problem is likely with the door switches. You can find my files "doorsw.txt" and "safety'txt" via Google. They give you the safety warnings and cover the diagnosis and replacement of the door switches. If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. They offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number. Be safe!
Oct 13, 2006 | Panasonic NN-H965 Microwave Oven
Panasonic NN-S541 Microwave Oven Logo
66 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
