Question about Avanti WC292D Wine Cooler
Set at 47 but reads 60 and not cooling. - Avanti WC292D Wine Cooler
My 47 ltr fridge is reading 60 Celsius on 12 volt but -2 on 240
That is because it is using a compressor for 240 and and an adsorption or peltair process for 12 Volts.
Mar 03, 2015 | Refrigerators
My seiki tv keeps shutting off?
Probably the set needs resetting. Call seiki and they will walk you through the steps.
Nov 02, 2014 | SEIKI Digital SE47FY19 47" LED TV...
1994 nissan pu 4x4 3.0 v6 air conditioning problem is cooling some. Low side 60 lbs of pressure: cooling on highway. At idle 60 lbs needle shakes somewhat. Was at one time cooling good this summer....
What is the high side reading? That's too high for low side maybe overcharged. Plugged expansion valve (no orifice tube) will cause low to neg psi low side.
Aug 19, 2014 | Nissan Cars & Trucks
Dehumidifier cycles off and back on in 2 minutes. Humistat on unit is 13% higher than room electronic unit which reads 47% with unit set on 60% to compensate. I am not so concerned with unit being off but...
I had this problem years ago when I lived in a more humid area, but I don't remember the exact details. I figured out that a switch was turning off the compressor. It may have been a heat sensitive switch, operated by a bi-metal actuator, and I either adjusted it someway, bending perhaps, or bypassed the switch. Sorry my memory is so hazy.
Aug 19, 2009 | GE Dehumidifiers
My 47 in vizio lcd tv. the zoom/widescreen function will not change to fit the full screen unless its an hd channel
the LCD TV is overheating. Solution A) allow air circulation. B) set up a small fan behind the TV C) once the set is cooled down save your preferences
Apr 03, 2009 | Vizio VO47L 47 in. LCD TV
Help me fix my 60 inch projection samsung
try unplugging the three convergence yoke plugs then try powering up the set if it powers up the Convergence ICs are bad and will need replacement.
Jul 25, 2008 | Samsung HCL4715W 47" Rear Projection...
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Avanti WC292D Wine Cooler Logo
18 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
