Question about Sylvania G-Netbook
Netbook will not connect to wifi - Sylvania G-Netbook
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Try configuring your netbook according to speed of Internet.
Posted on Jul 28, 2011
    Scholar:
  • 34 Answers
Maybe you hadn't fully set it up.
Try checking the following to see if any of these steps were missed.
On a "hooked up" computer, Google "digital gadgets.com". There find "Sylvania Products". Then click on "7 inch netbook support" and follow directions inputing to the 7" netbook as you go.
For item # 4, you find your "hot spot" name (on the 7" netbook) and click "connect".
For item # 5, you may have to call your Internet Service Provider (Charter, AT&T or whoever you pay for your internet) in order to get your "network keys" fill that in (on the 7" netbook) and then click "OK".
Next (on the 7" netbook) be sure you go to "Start", "Settings", "Control Panel", "Internet Options", "General" and complete "user agent (requires browser restart" by selecting:
"Default (same as windows XP)" or
"Same As Pocket PC" or
"Windows CE".
I selected "default" and was off and running.
Although this isn't a "lap-top" it is a really neat little machine and does a lot of stuff almost like one. It should be great for travel! It is a little slow and has small memory, but it's inexpensive and usb/sd ports are there. A regular universal mouse helps-just plug it into a USB port. I'm doing internet, movies, YouTube, word processing,etc like everything and I think a lot of people have way under-rated this fun little machine!
Posted on Dec 30, 2010
How to connect sylvania netbook to wifi
If windows is up and running make sure your wifi card is enabled (there's usually either a switch or one of the function keys will turn it on or off). From there in the bottom right corner look for your wifi icon or go to the control panel and find your wifi connection settings. From there just follow the directions on your screen to connect it to your wifi hotspot.
Dec 26, 2011 | Sylvania G-Netbook
I Am Able to Use WiFi On My Sylvania Netbook, Wen Im Connected I Can not Use the enternet. The web page Says "The Page Cannot be displayed" After I've Been Connected to Enternet Service A.K.A...
Note that not all wifi is internet activated....................if yours is and has worked for you before then do well to let me know, so i can get back to you
Aug 04, 2011 | Sylvania G-Netbook
Everytime i try to connect to the internet it says This webpage is not available
You need to confirm you are actually connected to the internet next. In the Wifi menu that you get to by double clicking the "pc" on the task bar you will see 3 tabs. If the first tab does not have all the IP, sub-net and default gateway filled in with legal numbers then you are not connected. Furthermore if you have an "IP Address:" that starts with 169.xxx.xxx.xxx then you are not connected to the internet.
If your Wifi setup includes a security phrase then under the wireless information tab it will take the following steps: "associating with.....", then "authenticating with...." then "connected to...."
The easiest way to tell if the problem is within a Sylvania Netbook running Win CE 6 is to take it to a McDonalds or other non-secure wifi location and see if it connects.
If it connects there but doesn't connect at "home" then your problem is between the netbook and your home setup not purely a Wifi not working issue.
There is a Wifi driver update available at the www.digitalgadgets.com website as well as the Sylvania Netbook Yahoo group. There are some additional troubleshooting steps at the Yahoo group.
Tom M.
May 28, 2011 | Sylvania G-Netbook
I BOUGHT THE 7"NETBOOK FOR
best way to connect to wifi is to use windows built in wifi connections. depending on the type of connection you will need to use a WEP key or WPA passphrase.
May 09, 2011 | Sylvania G-Netbook
Can not connect to internet
People often get confused about how to connect their netbooks (or laptops) to the internet. It's the same for cheap netbooks or expensive netbooks - you can connect pretty much all netbooks to the internet in four ways.... And it's really easy once you get past the jargon.
1 - Wired netbook connection using your home ISP
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - wifi netbook connection out and about
A really cheap way to get online when you're out and about is wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
See our separate feature on wifi for more about this.
4 - Your 3G netbook connection - at home or away.
netbooks.org.uk/wp-content/uploads/g3-dongle-300x164.jpg" width=240 height=131>
netbook dongle for 3G wireless internet
The final way to connect netbooks to the net - (and yes there are only four ways - I told you it was easy) is using the latest mobile phone network - 3G short for Third Generation. Just like a mobile phone, you can pay as you go or take out a monthly subscription with one of the phone companies to suit your needs. Then, using a little device like a USB stick called a USB modem, or a "dongle" plugged into your netbook, you can connect quickly and securely to the net in most of the UK and lots of places overseas. Some netbooks even have a slot to put your SIM card straight in
If you can use a mobile phone where you are, you can probably connect to the internet using 3G. Many people use 3G to connect netbooks to the net even at home and don't bother with a normal ISP.
Your pc could have a phone line input for built in modem DO NOT use that.
Use the lan inlet connector.When you connect the lan cable it should gain access at once.
Unless your connection is protected by a code.
If you have a wire less connection its probably protected with a code when you set the router up.
You have to enter the code to gain access to your network.
Here is a link that shows you how to repair the connection:
http://www.microsoft.com/windowsxp/using/networking/maintain/repair.mspx
And if you have wire less:
http://compnetworking.about.com/od/windowsxpnetworking/a/automaticwifixp.htm
Good luck.
Mar 11, 2011 | Sylvania G-Netbook
I am trying to connect my netbook to the internet and it won't connect because it can't find an ip address i have looked and tried everything what do i need to do?
netbook router ethernet or wireless
3 - Wifi netbook connection out and about
A really cheap way to get online when you're out and about is Wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
If you have a wireless router you must know the password you made when you set the router up.
Try also to look in your controlpanel network and shareringcenter.
Hope this was helpfull.
Mar 10, 2011 | Computers & Internet
My netbook will not go online I have tried my home wi fi and 2 diffrent public wifi
try to do the below troubleshooting :
1) Boot up your netbook. 2) Login to windows. wait until windows finish loading. 3) Make suer your WiFi is enable. Search for the button of keyboard shortcut like 'fn' + 'f2' (wifi symbol). 4) Search for wifi network nearby. 5) connect to one of them. 6) Usually, public enable wifi is using a DHCP setup. Go to you wifi adapter setup page and make sure it's already on DHCP mode. 7) You should be able to connect to the wifi network (public DHCP enable) by now. 8) If you still can't connect to the wifi, means its not a public DHCP enable network or you got a wifi adapter problem.
Good luck ;)
Mar 04, 2011 | Sylvania G-Netbook
My wifi on the netbook is not connected. How do you connect to web?
on the desktop, double click on the wifi power icon. click "on". then, bottom right, click on the wireless. find a wifi signal, and hit connect.
Feb 28, 2011 | Sylvania G-Netbook
Hi trying to connect my netbook to the internet
wifi connection? if you want wifi connection. just press FN ON THE SIDE IN YOUR KEYBOARD. AND PRESS F8 TO TURN ON YOUR WIFI CONNECTION.
Feb 01, 2011 | Sylvania G-Netbook
Sylvania G-Netbook Logo
109 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
