Manual for Technics tape deck model M6 - Audio Players & Recorders
  • 4234 Answers
SOURCE: missing ac plug for receiver
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Posted on Mar 25, 2008
  • 518 Answers
SOURCE: DEAD LEFT CHANNEL!!
The most common problem is a dirty record<>play switch inside the unit. Try this: Using a blank tape, press and release record/play buttons several times. This can clean the switch a bit. Then play a tape. If it fixes the problem, then you need to take the unit apart and use a plastic safe spray cleaner on the switch (Check at Radio Shack, their tuner cleaner Catalog #: 64-4315 will work fine). Spray it into the switch and then work the switch with the buttons several times.
Hope that helps...
Geno
Posted on Apr 04, 2008
thaurfen
  • 623 Answers
SOURCE: Technics RS-CH770 double tape decks
go here
www.donberg-electronique.com/warehs/group11.htm
Posted on Aug 13, 2008
welcomejee
  • 10594 Answers
Please check Capstan Motor working / rotating. If no, check its supply volts. If yes, then check Capstan Belt and FR Belt, should not be any cracks on it. If found cracks, please replace them.
djproaudio
  • 515 Answers
SOURCE: Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Posted on Dec 18, 2008
I have a rs-hd560 technics separates hi fi, tape deck broken
Malcolm hi! The tape decks are normally interchangeable as a unit and if you have a remote control that also operate your Hi Fi then you are stuck to the model.
Sep 11, 2014 | Audio Players & Recorders
I WANT TO PURCHASE ONLY CASSETTE TAPE DECK HEAD ; AMORPHOUS Z 3 HEAD FOR TECHNICS CASSETTE TAPE DECK
All you can do is look on E bay for someone who is selling such an item. The fact that they are no longer produced is going to make the price high. This is the reality of cassette tape decks these days.
Oct 02, 2012 | Audio Players & Recorders
Finding a Microcontroller for a Technics Tape Deck
I am sure there is one available or suitable sub . I wonder if technics would provide more information if you contacted them or a local electronics store.
A microcontroller may or may not be programmed for a specific purpose so, that also may be an issue if not purchesd froma source used for that device.
There is also a forum called tapeheads:
Technics RS-B49R - Tapeheads Tape, Audio and Music Forums
www.tapeheads.net >
http://www.tapeheads.net/showthread.php?t=49248
I found some links here and even a few sold for parts around 15 bucks:
Google
https://www.icom.co.jp/world/support/download/manual/disp_down.php?SWT=&ID=20010101177&GNR=Amateur&TYPE=Mobile&PDNM=IC-901A/IC-901E&INQWORDSWT=No&INQWORD=
Mar 26, 2017 | Panasonic Technics cassette deck rs-br465
User manual required for technics rsm215 tape deck
I can offer a service manual of this Technics deck. You can download it here.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Thanks.
gylacz
Mar 29, 2012 | Audio Players & Recorders
Connecting a tape deck and equalizer to a stereo receiver
Outs to Ins in a Tape Loop on the receiver. Model numbers make it easier if we or you can find the manuals for the receiver. If only one Tape Loop, nest the tape deck into the tape loop on the equalizer.
http://archiwumallegro.pl/technics_shge70-869230896.html
Sep 15, 2011 | Technics SH-GE70 Home Equalizer
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Tape deck not working on a technics rs-eh600. Small belt has slipped off, need advice in putting back on.
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Apr 02, 2010 | Technics Audio Players & Recorders
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
103 people viewed this question
 Grubhead
Grubhead
