Rudd Model# UBHK-17j11SFA. The L80-10F has opened. What is the purpose of this switch?
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: What does a watt risister do in electric heat circuit
That is a Temp limit. 80°F minus 10°F
Posted on Dec 19, 2008
burzerko
  • 254 Answers
SOURCE: rudd model ubhk-24jinfg
Check your filters inside the furnace, replace if needed. Then check to ensure that the fan is running inside the furnace. If these two things dont fix the problems, I would imagine you have low refrigerant issues. In that case you should call a service company.
Hope this helps ya please rate me.
Posted on Jun 22, 2008
Rheem heat pump
Model number of the inside unit is required
Jul 02, 2013 | Water Heaters
We have a Honeywell RTH230B programmable thermostat installed on a rudd a/c system. Everything works fine except the a/c unit cycles on and off about every 5 minutes.
Probably cycling on low or high pressure switch. You may be low on refrigerant, dirty filter or indoor coil, causing low pressure switch to open or the outdoor coil is dirty or outdoor fan not running at the proper speed causing the high pressure switch to open.
Jul 03, 2010 | Heating & Cooling
I have a model ubhk. the ecm motor comes on and runs for a few minutes then turns off. then repeats the cycle. i have a constant 24 volts to the board.
The ECM motor is hard to diagnose unless you have a teat kit. Turn fan to on position and see if it runs, If it does the same thing bad module. Check all wires going to fab fro loose connections. russ
Mar 24, 2010 | Heating & Cooling
Rudd Furnace Model UGRA-04EMAES Gas valve will not open
If the Igniter is not glowing, then the gas valve would not open to push out the gas. This indicates a Weak Igniter and you need to replace that.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 20, 2010 | Ruud Heating & Cooling
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
Rudd Achiever A/C float switch is clogged.
If the pump was bad the switch is supposed to shut down the ac so the water damage won't occur. You most likely have a bad drain.
May 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Jan 02, 2009 | Ruud UBHC Air Conditioner
Rudd model ubhk-24jinfg
Jun 20, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
