Question about iiyama E431S-B 17" LCD Monitor
Menu window opens and stays in view yet not called for it
Cannot turn off un-called for menu screen, it does not respond to control buttons it just sits there, sometimes it scrolls through its options of brightness etc.,
Re-installed the driver to no effect.
Hmmmm......
    Champion:
  • 220 Answers
This is a hardware issue of Monitor.
Most probable reason is defective key switches.Test switches some maybe leaky-Replace.
Please provide feedback and rate the solution.
Samir
Posted on Jul 08, 2008
TV power button on my RCA True Flat 27" screen TV
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Jun 17, 2013 | Televison & Video
Samsung shift buttons are disabled
shift button is broken...get external keyboard for cheap and move on
Jan 10, 2013 | Samsung R430 Notebook
How do you disable the on board videocard on a hp p6130f?
Turn on the computer. Press the left "Ctrl" key. When the start-up menu appears, select "Safe Mode" and press "Enter." Once the computer enters safe mode, click the Windows "Start" button. Go to "Settings" and open "Control Panel."
Double-click the "System" icon. Choose the "Device Manager" tab. Press the "+" next to "Display Adapters" to view installed display adapters. Highlight the adapter listed and click "Remove" then "OK." Close all open windows and restart the computer.
Press the "F1" key at the blue HP screen. Enter set-up and press "F5" and "Enter" to reset all data. Press "F10" to save and exit.
Right-click the "My Computer" icon on the desktop. Select "Properties" from the menu. Click the "Hardware" tab, then the "Device Manager" button. Expand "Display Adapters" and right-click the graphics card. Select "Update Driver" from the menu.
Choose "No," and hit "Next," then select "Install From a List." Select the option to show all hardware. Choose "Standard Display Types." Select "Standard Display Adapter (VGA)" and hit "Next." Don't restart the computer.
Click the Windows "Start" button. Go to "Settings" and open "Control Panel." Click "Add/Remove Programs." Remove any i810 and i815 chipset programs. Restart the computer. After it starts up, go into the "Display Adapters" section in "Device Manager."
Open the "Standard Display Adapter (VGA)." In the properties window, un-check the box "Exists in All Hardware Profiles." Click "OK" and shut down the computer. Open the computer case. Install the new video card according to the manufacturer's directions
hope this helps
Aug 26, 2012 | HP Computers & Internet
Hello excactly on christmas day my sansa e250 stoped responding, it turns on but it does not move on to the home page of the player, the screen stays at the sandisk screen, then it fades for about 2...
Try to do a reset, follow these instructions if this does not work. Reseat the battery.
Resetting your player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Dec 25, 2010 | SanDisk Sansa e250 MP3 Player
I am trying to print on a custom sized paper (4.5"
  1. Open the printing preferences by accessing the Properties / Preferences dialog box.
    For Windows 7
    • Click / Select the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
    • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the 'Page Setup' tab.
  3. Click the down arrow to the right of the 'Page Size' drop-down menu to view the page size choices..
  4. Select the size that matches the paper you are using, and then click the 'OK' button at the bottom of the screen to complete the setting.
Oct 28, 2010 | Canon i9900 InkJet Photo Printer
My lg kp500 menu disappeared
Add "Screen Settings" menu to your favourites button...... Now, after adding, open "Screen Settings> Top menu...... Select classic view instead of Scrolling view...... If U activate Scrolling View & install any theme, d main menu does not get displayed...... So, DO dis now...... Njoy......
May 15, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
I have a Canon PIXMA iP2200. It has started printing so small I can barely read it. Also it goes off the right hand side of the page so misses the end of sentences. Can you help.
Scaled printing
  1. Access the printing preferences by opening the printer Properties/ Preferences.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows 2000/Me/98
  2. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
Dec 12, 2008 | Office Equipment & Supplies
Usb connection not known / printer not connected
Solution: Uninstall / reinstall the printer driver (Windows) PIXMA Printers
Uninstall and Reinstall the Printer Driver (Windows) Follow the steps below to uninstall the printer driver:
  1. Select 'Programs' or 'All Programs' from the Start menu.
  2. Select the Canon printer driver you want to uninstall, and then select 'Uninstall' from the menu that appears.
    Note: Click here if your printer does not appear in the Windows 2000, Windows XP or Windows Vista Programs menu.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the un-installation is displayed. Wait until the "Uninstall successfully completed" message is displayed, and then click 'OK'.
    Note: If you use Add or Remove Programs to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in step 2.
In Windows Vista, Window XP or Windows 2000, use the steps below to uninstall the printer driver if your printer does not appear in the Programs menu.
Note: You will not be able to complete these steps, if User Access Control is enabled in Windows Vista. Click here for steps to temporarily disable User Account Control, so that the printer driver can be removed.
  1. Make sure your printer is connected and turned OFF (or the power cord is unplugged).
  2. Turn on your computer and log on as Administrator.
  3. Open the Printers window.
    For Windows Vista
    Right-click the Canon printer icon for your model printer and click Delete.
  4. Click 'Yes' to proceed with the deleting process.
  5. Click 'OK' to acknowledge you have deleted your default printer.
  6. Click 'File' from the Printers window then click 'Server Properties'.
    Note: For Windows Vista, click your right mouse button on any empty space within the window, and then select 'Server Properties' from the menu that appears.
  7. Click the 'Drivers' tab. Select your Canon printer from the list and click 'Remove'.
  8. Click 'Yes' to proceed with the deleting process.
    Important (Vista Users): If you turned off 'User Account Control', go back to User Accounts and turn it back on.
Follow the steps below to reinstall the printer driver:
  1. Turn off the printer.
  2. Connect the printer cable to the printer and the computer.
  3. Turn on the computer, and start Windows.
  4. Insert the Canon Software Setup and User's Guide CD-ROM into the CD-ROM drive. Setup Starts automatically.
    Note: If Setup does not start automatically, click 'Start' and then 'Run' from the taskbar. In the 'Open' box of Run window, type x:\msetup.exe (where x: is your CD-ROM drive letter). Then click 'OK'.
  5. When the Master Setup screen is displayed, click the 'Custom Install' button.
  6. Uncheck (click on the check marks) all items listed except for 'Printer Driver', and then click 'Next'.
  7. When the License Agreement appears, click the 'Yes' button after reading the agreement, and then click 'Next'.
  8. File copying begins. After all files are copied, the Printer Port dialog box is displayed. When the dialog box is displayed, turn on the printer.
    Note: If the port is not detected at this time, disconnect the cable from the printer and reconnect it.
  9. Click 'OK' to end the printer driver installation.
Note: If you previously used a Canon printer that was connected with a USB cable, a message reporting that the USB driver will be updated may be displayed. Click the OK button to update the USB driver and restart Windows.
Temporarily disable User Account Control
Note: In Windows Vista, the 'Remove' button will not be accessible (grayed out) if 'User Account Control' is enabled.
-To disable 'User Account Control' temporarily, open User Accounts from Control Panel.
Click 'Turn User Account Control on or off'.
-Click the check box next to 'Use User Account Control (UAC)...' to remove the checkmark, and then click the 'OK' button at the bottom of the screen.
-Click 'Restart Now'
-Once the computer has restarted you will be able to remove the driver.
I hope it helps!!!
Sep 06, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
RCA 52927
Solder Bridge on power switch to ground SW13201
Dec 10, 2007 | RCA P52926 52" Rear Projection Television
iiyama E431S-B 17" LCD Monitor Logo
138 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
James
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
