Question about Zodiac Pacer Pool Cleaner
Zodiac Pacer getting stuck near lower steps in shallow end of pool.
  • 640 Answers
There are several things that you will want to check if these pool cleaners are becoming hung on your pool steps. make sure that you are utilizing your return flow. If the return jets are not positioned properly, it will cause issues with steps. Position the return line directional so that you can only detect water movement on the surface 8 feet out from the wall, and aim it at the center of the opposite wall. In addition to your return lines, you will also want to confirm proper hose length and weight. Make any adjustments to the flow needed if it is too strong. If these options don't work, you will need to install a wheel deflector (#W69647).
Posted on May 09, 2011
My Zodiac pacer prefers to clean the walls of the pool instead of the bottom, and as a result it gets stuck on the walls over the water outlet
Here are a few things that you can try to get your pool cleaner to cover the entire surface of the pool. Add return diverters or divert return inlets downward. You may need to use the Pool Pulse feature to lower your flow. You might also need to add hose weights.
Dec 19, 2010 | Zodiac Pacer Pool Cleaner
Hi, we have a Zodiac pool creepy crawly pool cleaner which seems to work for a while, then get stuck in the one spot and not move in our inground pool.
With these pool cleaners, getting stuck in one spot is most likely the result of a waterflow problem. Check your water flow valve and make sure that it is adjusted correctly. make sure that you don't have any blockage that would prevent movement and cause the cleaner to stick in one place. This might seem like common sense, but make sure that you have enough hose to reach the entire pool. Many times, when this occurs, the cleaner cannot reach one part of the pool. make sure that your hose balance is correct also.
Oct 24, 2010 | Zodiac Pacer Pool Cleaner
Will not travel into shallow end
The first problem that you have is that you indicated that you have a Zippy pool cleaner by Zodiac. This cleaner is designed for above ground, flat bottomed pools. If you are using it for a dished above ground or in ground pool with a shallow end, the cleaner and the hose itself are not compatible with your pool. That is why it is not going to the shallow end of your pool. I would consider looking for pool cleaners that are designed for in ground pools if you want it to cleaner properly.
Aug 04, 2010 | Zodiac Baracuda Zippy Pool Cleaner
The Zodiac Pacer Baracuda keeps turning on its side of upside down. what is causing this?
Probably not getting enough suction to hold it down on the bottom. Have you backwashed your filter ? Try that and see what happens
Jun 02, 2010 | Zodiac Pacer Pool Cleaner
Pool cleaner working very eratic , stop /starts
you probably need to replace the diaphragm, unthread the nut directly beneath the wagon wheel, press the white tube downward and inspect the rubber diaphragm for damage or deformity. this is the most common problem with the Zodiac Pacer.
Apr 07, 2010 | Zodiac Pacer Pool Cleaner
Pacer does not run on INTEX pool pump, no pulsating action of diaphragm, pump sucking OK, Auto Weir Valve connected, pool 1,20m deep, round, 4,88m diameter
make sure to check the diaphragm inside, check for deformity or debris stuck in it. You can take the unit apart just below the wagon wheel and push the white tube downward to expose the diaphragm.
Feb 03, 2010 | Zodiac Pacer Pool Cleaner
My Zodiac Pacer seems to get stuck. There is suction (pretty strong). It can happen on the side or floor of the pool. If I pull it off, it starts going again, it's like there's too much suction or...
It probally is to much suction. You should have a dirveter valve where it hooks to the wall or the skimmer. This should have come with the unit and your manuel should describe it and it's function for you. if you don't have one your local pool store can help you out as these are generic in most case's.
Sep 30, 2009 | Zodiac Pacer Pool Cleaner
Doesn't clean shallow end
try aiming the return ports to direct the cleaner to the shallow end
Jul 31, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac pacer
Sounds like diaphragm is ripped
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
May 31, 2009 | Zodiac Pacer Pool Cleaner
Zodiac Pacer Pool Cleaner Logo
165 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
