Question about Frigidaire GLTF2940ES Front Load Washer
My washer will not spin, it still rotates but does not spin. Please help me. (It's 4 years old) It works in all other ways.
  • 1,531 Answers
The most common cause is a faulty door lock mechanism.you will alos need to make sure the drain pump is not blocked or restricted.
Posted on Dec 29, 2010
Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a kenmore elite oasis top load washer machine and I keep getting the error code f follow by 50. I did what the manual says to do but no luck. Help!! The washer machine is only two years old
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 29, 2009 | Washing Machines
LGWM2277HW Front Load High Efficiency set Code "LE"
may be a belt problem since you have this sound
thank you
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
Broken Washer
sounds like you have a broken drive coupling....will the unit agitate ok??
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Spin tub won't stop
LOL kinda wanna keep her alive I see?? an you got your moneys worth or someone did!! Ok your problem is probably the old mechanical timer on the face as the leaf switchs can break and not release as the cam goes past them.I checked with my source at www.repairclinic.com and they didnt list the model so make sure its correct. Timers cost about 75.00 all the way up to 150 bucks for some types. Good luck. You can go to that site to see for yourselfs if you get a good model # or call them.
Apr 12, 2006 | Whirlpool LSB6500P Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
