Question about Nixon El Dorado NIX0010 Wrist Watch
How put extra link for my nixon watch - Nixon El Dorado NIX0010 Wrist Watch
SOURCE: Nixon Watch band
Perheps this will help though it's not the same company http://www.allamericanwatches.com/site/626101/page/182605 Or get in touch with your local dealr you have a 2 year warraty on that watch http://www.nixonnow.com/za/NNS?PAGE=FAQ&MENU_ID=14
Posted on Jul 03, 2007
SOURCE: Armitron watch band needs extra links
I just called the main headquarters and they sent me 2 links for FREE!!! 1-800-840-2933 my model # for my watch is 20/1897T1 found on back. Hope this helps :)
Posted on Jan 08, 2008
SOURCE: remove the extra links in a luminox 3204 watch band
It was nothing more than split pins holding the links together. I pushed them out removed the links and pushed them back in.
Posted on May 13, 2008
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Posted on Feb 10, 2009
COULD YOU HELP ME PLEASE
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
http://online.nixon.com/us/en/repair-center
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
http://www.nixon.com/manuals/index3.html
Kind regards
Sep 12, 2014 | Nixon The Housing Watch
Hi, iam looking for nixon private ss gunmetal extra links!!! thanks a lot!!!
Contact the manufacturer with the model number. They will be able to provide you extra links.
May 12, 2011 | Watches
I need extra links for the Nixon 42-20 crystal bezel chrono. The watch is too small.
I have looked at the Nixon site and it says that spare links are provided in the bottom of the box, see below.
Do you still have the presentation box?
"The compartment at the bottom rear of the watch stand can be opened and closed, and it contains the user manual and extra links and pins."
Apr 07, 2011 | Nixon Watches
Hello! I just need some extra links for this
Contact your closest Nixon Service Center and we'll do what we can to resolve the problem. If you're in North America, visit our Online Repair Center or call us at 888-455-9200 from 8 to 5 pacific time, Monday to Friday, and we'll talk you through a solution or get you a service authorization number. Watches sent back to us without a service authorization number will not receive service. If you're somewhere else in the world, please go to the nixonnow.com homepage, select your country, then support/service for more details.
Note: Your warranty is not void if you do not register your watch.
Once we get your watch, please allow up to 10 business days for it to be processed. If you used our online service tool to send in your watch, you will receive an email notification from the Nixon Service Center when your package is received and when it is sent out. If you're in North America, we can provide you with the current status of your watch by emailing us at repaircenter@nixonnow.com or calling us at 1-888-455-9200 to talk to a Customer Service Representative.
Bands, straps and bracelets are not covered under warranty. Watches need to be sent in to the Nixon Service Center for band replacement. If you're in North America, visit our Online Repair Center and tell us how we can service your watch. You will then receive a service order number with shipping instructions. You may also call us at 1-888-455-9200 from 8 to 5 pacific time, Monday to Friday, and we'll set you up with a service authorization number. If you're somewhere else in the world, please go to the nixonnow.com homepage, select your country, then support/service for more details.
Please call our Service Center at 888-455-9200 for technical assistance on your watch. One of our representatives can assist you with setting your watch, answering any questions on watch functionality, or walking you through a solution for any technical issues with your watch.
Mar 24, 2011 | Nixon Banks Watch for Men
It says rom fail on my lodown 2 and i was wondering if anyone knew how to reset the watch?
Here some tips to deal with a Nixon Lodown:
1) Sleeping mood (display is off, all buttons lead to the same reaction: display shows time for some secs and then turns off again. This mode is for battery energy saving, switch it on and off by holding (c.a. 2 secs) the light button.
2) ROM FAIL: it happens that the lodown shows ROM FAIL and constantly restarts. It happened on my watch while I tried to change time zones. Here is what to do about it: Bring it to a professional watch repair store and get the battery replaced. The watch restarts automatically and works perfectly fine again. DON'T send it to Nixon, they will charge you for shipping, battery replacement, the new battery etc. Although it should be covered by the guarantee. Just get a new battery, it cost me 16 USD and the watch is good again, waterproof and works perfectly. Nixon authorized repair centers will charge you extra for pressure testing. I had this on my second Lodown, after I had it two weeks only...
3) Watch freezes: All digits are on at the same time, none of the buttons brings a reaction. I had this problem on my first lodown. Just get a new battery, that solves the problem. But again DON'T use authorized Nixon repair centers, it costed me almost 45 USD, just to get a new battery. Although the watch was only 1 year old and guarantee should have covered this case.
In general the Nixon Lodown is a good watch, looks good, has all features you need, as long as it works. The problem with the watch is, the above problems occur pretty often. I have my second Lodown now and I am very disappointed with the Nixon customer service. Although clearly guarantee cases, they will charge you for every single problem you have with the watch. My advice, bring the watch to a regular watchmaker.
After all, I don't understand why the Nixon Lodown manual does not mention all the above issues. The manual is completely useless, very poor from Nixon. You have to dig online to solve any issues on the watch. In summary: The Nixon Lodown watch is good, Nixon customer service and guarantee is a joke. ROM FAIL and freeze is solved with replacing the battery.
Jan 26, 2011 | Nixon Lodown Watch
I need a couple of extra links to my black and silver Super Rover
mcdevito75 here, BEST BET, look for a small watch repair shop in your area, chances are you"ll have to order these links from Nixon watch.
Jul 12, 2010 | Nixon Super Rover NIX0123
Get the user manual for nixon banks watch
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
Apr 25, 2010 | Nixon Banks All Gold/Black Watch
Nixon El Dorado NIX0010 Wrist Watch Logo
141 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
