Question about Dometic NDR 1292 Refrigerator
Ineed to replace the 12 volt fuse on my dometic refer and don't know what size fues to use.....
If you are talking about the fuse on the circut board, it tells you the size on the black cover, covering the circut board. I think it's a 1 amp and 3 amp glass fuse.
Posted on Jan 01, 2011
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
How to hook up a 12 volt battery from converter to fridge
on back panel there is a plug into outlet then on bottom below control board a bus shows 12 volt and ground
Aug 01, 2014 | Dometic RM2193RB Compact Fridge...
How to hook up a 12 volt wiring from converter to fridge
Is this a new fridge or the one that came in a trailer? If it is installed it should be wired, have you checked fuses? If it's not installed there should be instructions with the frig or check the Dometic web site.
Wire hook-up
see schematic on side of inside back cover if 120 volt plug that goes to outlet then if 12 volts from black and green ground go to block they should be marked
Jun 18, 2013 | Dometic RM2620 2 WAY REFER
I need to know why my Dometic RM2802 will not operate on the gas side
Does it try to ignite at all? Have you checked for 12 volts at lugs near bottom of fridge at back (remove cover outside) ? Pull cover on control box and check for blown glass fuse as well. Let me know what you find. Unplug it from receptacle when testing, and checking for fuses.
May 14, 2010 | Dometic RM2652 Refrigerator
Cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
May 03, 2010 | Dometic NDR 1292 Refrigerator
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
Model 211 Dometic, can not keep pilot lit, do I have to have it hooked up to 12 volt
Dometics work on propane, 12 volt or 110 volts, if pilot won't stay lit then you prob have a control board defective. Apply 12 volts and see if pilot stays lit, then you will know.
Oct 16, 2009 | Dometic Refrigerators
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Feb 13, 2009 | Dometic RM2652 Refrigerator
Dometic NDR 1292 Refrigerator Logo
258 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
