Question about Sewing Machines
My daughter received a new kenmore 19112 with drop in bobbin. We have threaded the machine and dropped in the bobbin but cannot get the needle to loop into the bobbin thread. I know I am probably missing something stupid. Help! I'm trying to teach my daughter and look like an idiot.
    Genius:
  • 1,788 Answers
Do you have your needle inserted, facing the right way? Flat side faces away from you. If, that doesn't help, take it back to Sears and have the salesperson look at it, you may have a defective machine and you are not an idiot at all. You may as well have one that works right, instead of waiting.
Posted on Dec 29, 2010
I just recieved an older kenmore 24 stitch sewing machine and it has no manual with it , my problem is why wont the machine pick up the bobbin thread ?
You can probably find a manual from Sears. They carry a ton of Kenmore user manuals.
First thing to always try--insert a brand new needle!
Bobbins do usually have a specific way of being loaded. Most machines require the bobbin to be inserted into the bobbin case so when you pull on the thread tail, the bobbin turns clockwise (this is when you are looking at the backside of the bobbin case - at the bobbin). Also, be sure to thread the bobbin thread through the bobbin tension mechanism.
Tip how to put bobbin into the bobbin driver on sewing machine
If the upper thread is not picking up the bobbin thread, it is usually because there is a timing issue (means the needle is arriving at the bobbin at the wrong time to connect with the bobbin thread).
Sewing machine won pick up bobbin thread hook timing fix
P.S.--if your Kenmore is non-computerized (ie, mechanical) be sure to oil using fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil (NOT cooking oil, 3-in-1, WD-40, or old stinky brown stuff that may be in the accessory box). Apply a couple of drops every place metal rubs on metal (while hand-rotating the handwheel). Do NOT oil nylon, rubber, or belts!
Jul 11, 2016 | Kenmore Sewing Machines
Machine is binding up
New needle, right way around, and thread again from scratch, manual in hand. Make sure you're threading with the presser foot up. Raise the bobbin thread. Start each and every seam thus:
1. Place the work under the needle. Use the handwheel or needle up/down function to drop the needle into the fabric.
2. Drop the presser foot.
3. Hold the bobbin and top thread ends together and take about 3 stitches.
4. Drop the thread ends and sew normally. See also: http://www.picturetrail.com/sfx/album/view/22521551 last pair of photos.
Apr 28, 2014 | Euro-Pro 9105 Computerized Sewing Machine
My Kenmore Sewing Machine's needle is locked down
best suggestion try inserting new needle. cotton up the top suggests needle problem or incorrect top thread tension, this would effect the feed dog. Because thread is black and most recent use was with pink, the problem thread was already there perhaps in cavity above bobbin but below throat plate. I have had this happen and nothing will move, untill needle released. The bobbin holder tension may also need adjusting after the knots of black cotton are removed.
Nov 07, 2013 | Kenmore 15516 Mechanical Sewing Machine
Needle thread wrapping around bobbin case.
Hello Crystal, I also have had problems in the past with drop-in bobbins . I had to experiment with different model bobbins . The cause I found was due to the bobbin was not tall enough in the drop-in bobbin case. When sewing , the bobbin would rock in the bobbin case and the top thread would get caught on the bobbin instead of going over the top of the bobbin, causing the rats nest that you described. I would recommend finding a taller bobbin to fit in the bobbin case. There are about five different bobbins that will fit in there, but only one that will work properly. Knowing the exact model number of your machine would be a great help to finding the correct bobbin.
Oct 08, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
My Janome needle thread will not pick up the bobbin thread! I have checked threading and needle and bobbin case...nothing works!
Your Machine is out of time, you probably broke a needle or sewed over a pin. take the machine to your locsl deler to be re timed. about 90.00
Jun 13, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin thread one big snarly knot
First ensure that your bobbin is threaded correctly. Most drop in style bobbins the thread will feed off in a clockwise motion. Also make sure to only move the hand wheel (on the right) toward you (counter clockwise). When you begin sewing ensure that you start with the needle in the fabric and when you end that your needle is in the highest position.
May 29, 2007 | Kenmore 19233 Computerized Sewing Machine
Machine wont pick up bobbin thread
hi,try loosening your needle and pull it down a fraction then tighten it back up,i had same problem,good luck
Mar 11, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sewing Machines Logo
83 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
