Question about RCA 32V524T TV
We lost the remote and we are trying to hook up our Wii to the front panel box. How do we change the input to the front panel without the remote
  • RCA Master
  • 5,163 Answers
On the side of the TV there are a set of buttons. An Input button is next to the Menu button and will let you access the different sources connected to the TV. For the front panel input, look for the source labeled Front. (There are also volume control and channel +/- buttons.) The button order is Input, Menu, Vol -, Vol +, Ch -, Ch +.
If you want, you can get a substitute remote that is guaranteed to match the original remote's features here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=32V524T&uuid=12935850039140 .
I hope this wants.
Posted on Dec 29, 2010
  • Anonymous Dec 29, 2010
    We have buttons on top of the TV which are Menu, Vol- Vol Ch- and Ch but no Input button
    no buttons on side of TV either
  • Cindy Wells Dec 29, 2010
    I must have a slightly different generation of the RCA 32V524T TV (made by Thomson for RCA) where they added the Input button. In that case, you can need a replacement remote. The one in the link (from remotes.com) from my earlier response will work. If you have a different model, search using just the model number without the brand.
    Alternatively, any of the higher end universal remotes with a Source or Input button should have a code that will enable the input change to work. (The cheapest ones often don't have an Input or Source button.) It may take some time to run through the codes to find the right one. Several codes may only work for the basic functions (channel and volume change and power control). The universal remotes that can be programmed via a computer (USB connection) take less time to program and will control the input.
    I hope this helps.
    (I'm sorry that my initial response didn't help.)
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
How do i play wii i have hooked up but do i put on certain channel or how do i get to video mode
You should have a input or video button on the remote, some remotes use source. Use that button until you get the right video source. Without the tv model it is hard to tell. If the wii is on, once you cycle through to the right input you will see the screen that the wii is displaying.
Jul 16, 2011 | Televison & Video
I have a yamaha htr 6130 receiver. Hooked up to it are a dvd player, cable box, and the t.v. Where (which inputs) do I put in the wii connections? I know it's the yellow, white, red ... but there are so...
Your problem is not the Yamaha reciever. You need to figure out how to switch your tv remote to the inputs you have tried to plug the Wii into, Your TV remote should have some sort of "source" or "input" selection button, or it may have a row of buttons that are labled. Without knowing the brand of your TV or seeing the remote, I can't be more specific, but clearly this is a tv issue. You could also use the video out on your 5.1 reciever, but first solve the tv remote issue. Keith
Feb 21, 2011 | Yamaha HTR-6130 Receiver
Where do i find INPUT SELECTon zenith tv sy2779dt,trying to hook up Wii and default Wii screen does not come up. manual says to change IS. don't have orig remote, only dish 500.is there a way to change IS...
Most tv's have a physical button on the front and it will either be labeled input or source-source select. If thats not the case on your tv, look for a menu button and try to navigate through the tv menus until you find tv input or source select. If that still does not work, you can use your dish 500 remote and if you already use that to turn the tv on and adjust volume, you can probably use it to change the input. To do this, select the tv mode on your dish 500 remote, and then press the source or input button until you get to where you need to be. Once thats done, make sure you return your remote to sat mode or you will not be able to control the dish reciever. Hope this was helpfull to you.
Thanks
Jan 03, 2011 | Zenith SY2765S TV
I am trying to hook up Wii but I don't have the remote for the tv. When I bought the tv it was a floor model and it didn't have a remote. I am trying to change the channel for input...channels on tv
Buy a universal remote with an input button if there is no input selection option on the television. Would be helpful if you mentioned the brand and model of your TV
Jan 20, 2010 | Memorex MLT3221 32 in. LCD TV
No remote, front buttons don't work... how to change channels??
Hold down the MENU button on the control panel for more than 8 seconds to unlock buttons.
Lone99star
Jun 05, 2009 | Mitsubishi VS-6043 60" Rear Projection...
How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Jan 08, 2009 | RCA Scenium L50000 Television
Lost my remote
Sometimes you can change the input by just clicking the channel button up >>> after the highest tv channel it'll go to Input 1, Input 2, etc. That's worked on one of my tv's but not all of them so it might work for you, too. Next suggestion would be to buy yourself a couple of universal remotes & keep them in a junk drawer for when you need one! We've found this PRICELESS!!! (Buy a couple when they're on sale & store them for those days when the remote was devoured by that oh-so-sneaky sofa!)
May 18, 2008 | Durabrand DWT1304 13" TV
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
May 15, 2007 | Zenith A25A11D 25" TV
RCA 32V524T TV Logo
283 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
