Question about Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI
Machine runs but I am getting no heat - Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI
On a water cooled scotsman ice machine, should the water be running out of drain line contiuously as its making ice? be cause it just runs all the damn time and thats a huge water bill ...
On a water-cooled system, by design the heat from the machine is being transferred to running water that carries the heat away. Some installations pump this "waste" water to a heat-exchanger or cooling tower (typically on a rooftop), where the heat is transferred again, this time to the air. The water with the heat removed is then recycled back to the machine, where the process is repeated continuously. There is thus no "wasted" water.
If your cooling water is just running down the drain, that's a terrible waste of water and money. Try to find a way of recycling the water by removing the heat and re-using it. Think of ways to use the "free" heat in the water.
Alternatively, buy a proper rooftop heat exchanger and pump the water through it, or, get an old car radiator or air conditioning condenser and a decent blower, and make your own.
Remember that your machine needs constant cool water in order to avoid overheating the system.
Oct 31, 2013 | Kitchen Appliances - Others
Dryer gets too hot in any cycle setting, even air only
If this machine is an electric dryer you probably have a short in your heating element causing constant heat when ever machine is running. Replace heating element.
Aug 05, 2013 | Dryers
I have a Whirlpool washer. It will fill and run through the first cycle and then stop... What would cause this?
I would pretty much guess it's a faulty heating element. After the machine stops after filling with water and running a while to get the clothes wetit stops to heat the water. Listen carefully to hear the water heating up, it sound simular to an electric kettle. If this does not happen the program is unable to advance.
Apr 06, 2011 | Whirlpool Washing Machines
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
Water not pumping
Typically this is caused by the heating/water unit inside the machine drying out. Not being totally familiar with your machine let me offer this suggestion: if you have a "hot water" function that allows you to run hot water out of the machine use it to allow water to get back into the heating unit. Once water flows through without interruption you should be able to brew coffee again. I know this is the case with Jura machines and the problem you described is identical to what happens with those machines when the internal heated water tank runs dry.
Mar 30, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Machine runs for about 5 minutes on normal cycle than stops and flashes f 05. It works on other cycles
F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
www.repairclinic.com
thanks.
Jul 13, 2009 | Whirlpool Washing Machines
Run but want heat up
the heating coil is faulty so even though the machine starts it does not heat up.heating coil needs to be replaced compulsory to get ur machine back to work . its a very common problem in dryers.
thanks.
Sep 16, 2008 | Kenmore 62602 Electric Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag dryer runs, does not heat
check for continuity in the thermal fuse, also check heating element. make sure you have disconnected the power first. if this is a 220 volt machine make sure you are getting 220 to the machine. if one leg of the voltage has dropped out the motor will run but unit will not heat
Oct 05, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Northstar Gas Powered Wet Steam & Hot Water Pressure Washer 3000 PSI Logo
49 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
