Question about Funai TruTech DVDVCR Dual Recorder
I have a TruTech DVD/VCR combo that will not power up. The inside fuse is good, but no sign of life. Looks like a bad power supply. Any better ideas?
  • Funai Master
  • 6,771 Answers
Yes! I would agree with you, sometimes I have found a bad capacitor right next to the power transistor, it might show a slight bulge at the top of the capacitor.
Posted on Dec 29, 2010
Panasonic dmr-es30v will not turn on
The circuit board may look good, but a power surge can damage the tiny resistors, diodes, and transistors. Any one of those mention can render the unit inoperable.
Feb 27, 2014 | Panasonic DMRES30V DVD Recorder/VCR Combo
A power surge seems to have burned out my Toshiba TV/VCR combo.
The power supply does have fuses. They require removing the back cover of the unit. Note: High voltage is present so I recommend having a pro do this.
In units like this many times a part will fail and the fuses will be ok. At this point you will need a pro again.
I would replace the unit. The repair cost could be in the 60 dollar range depending on the severity of the problem and shop rates in your area.
May 08, 2010 | Toshiba MD13P3 13 in. TV/DVD Combo
We've had ours for 3 years and when it no longer turned on we found the inside fuse blown. We put a new fuse in of the same rating, it goes right out too. What usually goes in the power supply to have the...
Hi, Sounds very much like the capacitors in the power supply have failed and stressed the switching regulator/mosfet/transistor and caused it to go short.Unless you are conversant with switching power supplies, be prepared to spend some money.
Mar 17, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a trutech undercounter mount DVD/TV combo. It was working fine, and all of a sudden it turned off and will not come back on. We checked the outlet and it is fine.
Unplug the power cord from wall outlet and take the unit apart follow the power cord inside the unit it goes to the fuse. Check the fuse most of the time the fuse is bad.
Jul 22, 2009 | TruTech LMD-5702RT Portable DVD Player
No power to dvd-vcr player
check the circuit breaker. plug something into the outlet that you know works and see if it turns on.
dont think that there is a fuse inside. If the cables seems good ( ohm it out) then the unit might be shot. sorry...
Feb 14, 2009 | Sanyo DVW-7000 DVD Player/VCR
Blown dell motherboard
Have you checked to make sure it wasn't the power supply? If this motherboard is still inside the pc and the cd/dvd lights up, or the network card shows life, fans, case lights, etc: than I would rule bad mobo. If nothing shows signs of life, try power supply or even better maybe a lose connection.Check all cabling and wire plugs. Clean out any dust.
Dec 29, 2008 | Dell Computer Refurbished OPTIPLEX SX270...
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Daewoo VCR/DVD combo not turning on
check you power button it might be bad
Aug 24, 2008 | Funai Emerson DVD/VCR EWD2004
No power to DVD combo player. VCR OK.
The power circuit for the DVD and the vcr are separate look for a open diode and transistor in the circuit that supply the DVD.GOOD LUCK.
Apr 26, 2007 | GoVideo Go Video DVD/VCR Combo
Funai TruTech DVDVCR Dual Recorder Logo
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
