Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
Looking for repair diag. for Aermotor mdl # c48b48c09 so as to find out the extnt of damage to the pump, when pwer short caused pump to run cont. till lossing prime ,selmaknight@aol.com
2 Suggested Answers
leroywolff
  • 42 Answers
SOURCE: I have an Aermotor nonsubmersible
It sounds to me like there is a hole rusted through the discharge pipe of the pump. If you are able to
look into the cistern with a flash light while the pump is running. You might see water swirling around
the pump. This means the pump is good, but the pipe is bad.
Posted on Nov 05, 2010
A/t Cont fuse Nissan Navara keeps blowing
Fuses only blow if the load is heavier than it is designed for. Most likely causes are, Shorted wire. Defective part To small fuse. If you have the correct fuse then somewhere in the wiring circuit is asking for too much. You need a good electrical tech to find out your cause. If it blows the fuse once a month then this can be a pain in the rear to find the cause. Most wiring is made very durable. Look for damaged areas, or where work has been performed in the past and wiring has been disturbed and not properly secured. Look for alterations, Hope that helps.
Dec 28, 2012 | 2005 Nissan Pickup Navara
How do ya fix codes p0320&p0340
Ford Crown Victoria, Mercury Grand Marquis, Marauder, Lincoln Town Car 1999-2005
4.6L V8 - Auto 2
Print
Trouble Code: P0201
Cylinder 1 Injector Circuit Malfunction
Possible Causes:
Injector 1 connector is damaged, open or shortedInjector 1 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0202
Cylinder 2 Injector Circuit Malfunction
Possible Causes:
Injector 2 connector is damaged, open or shortedInjector 2 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0203
Cylinder 3 Injector Circuit Malfunction
Possible Causes:
Injector 3 connector is damaged, open or shortedInjector 3 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0204
Cylinder 4 Injector Circuit Malfunction
Possible Causes:
Injector 4 connector is damaged, open or shortedInjector 4 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0205
Cylinder 5 Injector Circuit Malfunction
Possible Causes:
Injector 5 connector is damaged, open or shortedInjector 5 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0206
Cylinder 6 Injector Circuit Malfunction
Possible Causes:
Injector 6 connector is damaged, open or shortedInjector 6 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0207
Cylinder 7 Injector Circuit Malfunction
Possible Causes:
Injector 7 connector is damaged, open or shortedInjector 7 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0208
Cylinder 8 Injector Circuit Malfunction
Possible Causes:
Injector 8 connector is damaged, open or shortedInjector 8 control circuit is open, shorted to ground or to powerPCM has failed (the injector driver circuit may be damaged)
Trouble Code: P0219
Engine Over-Speed Condition
Possible Causes:
Engine operated in the wrong transmission gear positionExcessive engine speed with gear selector in Neutral positionWheel slippage due to wet, muddy or snowing conditions
Trouble Code: P0230
Fuel Pump Primary Circuit Malfunction
Possible Causes:
FP or FSV circuit is open or shortedFuel pump relay VPWR circuit openFuel pump relay is damaged or has failedPCM has failed
Trouble Code: P0231
Fuel Pump Primary Circuit Low Input
Possible Causes:
FP or FSV circuit is open or shorted to groundFuel pump relay VPWR circuit open or fuel pump relay failedPCM has failed
Trouble Code: P0232
Fuel Pump Secondary Circuit High Input
Possible Causes:
Fuel pump relay contacts always closedFuel pump ground circuit has high resistanceFuel pump secondary circuit is shorted to powerLow speed fuel pump relay damaged or related circuit problem
Trouble Code: P0297
Vehicle Over-Speed Condition
Possible Causes:
The code indicates the vehicle was driven at very high engine speed (rpm) for too long. The PCM temporarily prohibits high engine speed by disabling the fuel injectors with this code set.
Trouble Code: P0300
Random Misfire Detected
Possible Causes:
Base engine mechanical fault that affects two or more cylindersFuel metering fault that affects two or more cylindersFuel pressure too low or too high, fuel supply contaminatedEVAP system problem or the EVAP canister is fuel saturatedEGR valve is stuck open or the PCV system has a vacuum leakIgnition system fault (coil, plug) affecting two or more cylindersMAF sensor contamination (it can cause a very lean condition)Vehicle driven while very low on fuel (less than 1/8 of a tank)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0301
Cylinder Number 1 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 1Fuel delivery component problem that affects only Cylinder 1 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 1TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0302
Cylinder Number 2 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 2Fuel delivery component problem that affects only Cylinder 2 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 2TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0303
Cylinder Number 3 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 3Fuel delivery component problem that affects only Cylinder 3 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 3TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0304
Cylinder Number 4 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 4Fuel delivery component problem that affects only Cylinder 4 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 4TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0305
Cylinder Number 5 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 5Fuel delivery component problem that affects only Cylinder 5 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 5TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0306
Cylinder Number 6 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 6Fuel delivery component problem that affects only Cylinder 6 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 6TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0307
Cylinder Number 7 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 7Fuel delivery component problem that affects only Cylinder 7 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 7TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0308
Cylinder Number 8 Misfire Detected
Possible Causes:
Air leak in the intake manifold, or in the EGR or PCM systemBase engine mechanical problem that affects only Cylinder 8Fuel delivery component problem that affects only Cylinder 8 (i.e., a contaminated, dirty or sticking fuel injector)Ignition system problem (coil, plug) that affects only Cylinder 8TSB 02-16-2 contains repair help for this code (LS & T-Bird)TSB 03-14-4 contains repair help for this code for COP ignition
Trouble Code: P0315
Unable to Learn Crankshaft Variation
Possible Causes:
Inspect the CKP sensor for damageInspect the CKP sensor for debris on the rotorInspect the crankshaft pulse wheel for damaged teethInspect the crankshaft pulse wheel for wobble (loose condition)
Trouble Code: P0316
Misfire in the First 1000 Revolutions
Possible Causes:
Check for CMC DTC P0136, P0156, P0171, P0172, P0175, P1130 and P1150. Repair these adaptive fuel and HO2S codesCheck for any other CMC in memory. Repair these codes first!Ignore P1000 codes that set during KOEO and KOER Self-Test
Trouble Code: P0320
Ignition Engine Speed Input Circuit Malfunction
Possible Causes:
Inspect for problems with an Aftermarket 2-way radioInspect for signs of "arcing" at one or more of the ignition coilsInspect the Profile Ignition Pickup (PIP) unit inside distributor (check for damage or corrosion at the PIP sensor connector)PIP sensor is damaged or it has failed (distributor models)Ignition control module (ICM) has failed (Distributorless models)Trouble Code: P0340
Camshaft Position Sensor Circuit Malfunction
Possible Causes:
CMP sensor circuit is open or shorted to groundCMP sensor circuit is shorted to powerCMP sensor ground (return) circuit is openCMP sensor installation incorrect (Hall-effect type)CMP sensor is damaged or CMP sensor shielding damagedPCM has failedTSB 02-22-1 contains repair information for this trouble code
Nov 16, 2012 | Ford Cars & Trucks
'05 HD FXSTD ......New Battery exploded!! When putting another battery in , the battery 15amp fuse blows. Where to start diag??
you'll need to look for a dead short in the system use a volt ohm meter to trace the short to verify short touch + lead from volt meter to + battery wire then touch the = lead to ground then trace from there
Sep 17, 2012 | Harley Davidson FXSTD Softail Duece...
I have an Aermotor nonsubmersible pump rpm 3450 1/2 hp model # c48b48c09 for my cistern. I thought I was out of water as I could only hear the pump humming and my washer only filled 1/2 up...but I am not...
Nov 04, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
When you press the brakes on my 2002 blazer everything comes on fuel pump head lights radio . how can i fix this
You have a short in your fuse box or wire harness at your fuse box. Inspect the fuse box under the hood and on the side of the dash and look for any signs of corrosion or damages. Repair or replace any damaged component found caused by corrosion or bad wire harness causing a short.
Good luck and thank you for using Fixya
Mar 09, 2010 | 2002 Chevrolet TrailBlazer
Dell 1501 vios2.6.2. reads missing operation system..then after 18 seconds it shutdown..pls..help... anybody has many opinion to fix it i appriciate it very much. tnks..
Missing operating system errors generally indicate a hard drive read failure. This could be for several causes.
  1. Hard drive failure (Run diags on the drive, if you get an error code, then time to replace)
  2. Software corruption (Too many possible causes to list
  3. Virus
So run Diags Fn+ Power, see if HDD passes diags, if it does, then boot to your windows CD and go to recovery console in XP, (Repair My Computer in Vista/7) in recovery console, run the command CHKDSK /R
If that doesn't resolve, then try a repair install of windows;
http://www.fixya.com/support/r3874510-find_information_windows_installations
Jan 12, 2010 | Dell Inspiron 1501 Notebook
My Polaris booster pump has started making a very load noise. The noise seems to come from the motor side of the unit. Any idea what this could be?? Mike
The bearings are failing. Letting it run is ok for the short term but the longer you run it that way the more likely additional damage will occur to the motor and pump. A typical repair of the motor bearings and a new pump seal (which probably caused the problem in the first place) is around $60 - $75 at a local motor and pump repair shop. Look up in the yellow pages under electric motor repair.
Dec 20, 2009 | Garden
I need wireing diag for filter systen for frymaster mdl 350oced sn 9608ieo147. gas fryer. thanks i just need wireing diag
Hello. I think this is what your looking for:
http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/manuals.html
Go here, scroll down the page until you get to H50 units, and click on the link that has the SP manual, 819-0001 next to it, page 32 describes the different filters, and 61 has the wiring diagrams.
Hope that helped, and thank you.
If you need more help, "ask me"
Apr 10, 2009 | Frymaster Dean Kitchen Appliances - Others
Solid audio f29 2 channel
With the no name amps theres not alot you can do. Even with the high end amp companies you cant get much info and parts out of them.. If you happen to be in the chicago area i do run a small repair shop and i would be happy to take a look at it and see if theres any way to repair it....
Aug 16, 2007 | Solid Audio Formula Series F21 2-Channel...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
159 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
