Question about Lincoln Roosevelt Popcorn Maker
Not sure who manufactured machine. Model # is UE40010, with no other logo info. Motor burnt out: Euroka M6030-1203-1. Can anyone help me on this. Ron
If the stirrer motor on the UE40010 popcorn popper ceases to work, it is very likely to be the thermal protection switch that has burnt out. It's an easy fix, for anyone with some basic electronics skills.
Just remove the top by undoing the 12 screws using a Philips screwdriver. Locate the motor (it has a cooling fan facing up, and a red and black wire coming from it. You do not need to disassemble anything. Just carefully remove the black insulating material ("tape") without damaging the wires underneath (you do have unplugged the machine from power, right?!). Concealed under the black tape, attached to the black wire, is a white component with 102C printed on it (if I remember correctly). If you short the legs of this component and then test the motor, it should now operate. This confirms that the thermal cutoff switch is the dead component. You can find a replacement part for around a dollar from Digikey or Mouser. Just search for "thermal cutoff" and select one rated for a functioning temperature around 102-104 deg C.
Simply clip/desolder the old component, and solder the new component into place. Use appropriate insulation (heat shrink, electrical tape, etc.) to cover any exposed wires. Then tape the motor coil back up with electrical tape.
--CalgaryBen
Posted on Jun 26, 2014
I tracked the machine back to Sears. I have the same problem on mine burnt motor
Posted on Jan 06, 2014
Flashing a code 4E what does this mean
A lot of wash machines 4E is a water sensor error but I do NOT know for sure until you share with me the Manufacture, Model and manufacture date if available . See specifications label for this info usually on door or rear of frame
Apr 18, 2016 | Washing Machines
My dryer is putting out a burnt plastic. Please advise on what I should od, have only had since July. 2014
check the drum see if it moves easy. if not you have something logged between the felt and the frame of the drum. use flash light.
it maybe dragging so hard the belt if it has 1 it is slipping around the drum when the motor is driving the drum. it cloud cause the burning smell... need model to help further..... not sure how often you use it,
you maybe smelling the heating element breaking in... not sure what it is made of..... if you still have warranty call manufacture or the place where you purchased it. and ask them if anyone has reported same issue. model of dryer would help........
Sep 26, 2014 | Samsung Dryers
Popcorn mach model ue40010 parts
Most likely a metric, but usually that part is not replacable.
Oct 12, 2013 | Kitchen Appliances - Others
Washing machine is showing pau13 and has a funny smell
Wrong category. You will get a faster response if you post the Make, Model of machine. Give as many details as you can. For example: "a funny smell comming from the motor, or a burnt electronic smell. I wold suggest reffering to the Machine's User manual, error codes/troubleshooting section. Or the Manufacturer's website, troubleshooting.
Dec 30, 2012 | Computers & Internet
We are trying to fix our vacuum and we can not get the cover off to see what the problem is. The Carpet mode is not working and the motor is not running. Any advice? Thanks Katie
Hi, this could be many things. If I had more info. on the make and model it would help. It could be anything from a burnt out motor or a simple reset button. Whay happened when it stopped cold be valuable info. for me. Please gt back to m with the make and model,ie. upright or cannister. Chris
Feb 21, 2011 | Electrolux Vacuums
The plastic gears in the gear motor are stripped out where can I find parts for it Its a model ue40010
These gears are used in many of the 8oz poppers: http://www.keepitpoppin.com/popcorn-machine-parts/motor-gearbox-8oz.html
Feb 10, 2011 | Lincoln Roosevelt Popcorn Maker
Has anyone reported smoke coming out of the unit and the control unit being burnt.
What kind of unit is it? What Brand, model, etc.. How long have you had it. Is it hard wired. This is an indication that you have a short somewhere. Is the item still under buyers warranty, or from the manufacture. If you can provide me with additional info I might be able to assist you further. Hope this helps.
JimmyC
Sep 25, 2009 | GE 24 in. Monogram ZBD6880KSS Stainless...
Good afternoon, I purchased a Roosevelt 8 ounce corn popper about 1-1/2 years ago. It is used once a week for approximately 1 hour. The heating element has failed and I am trying to purchase either a new...
Hi Roy,
Here is a toll free number to DTX International. With the model and serial info, I'm sure they can assist you in a replacement part:
DTX International
9855 North Front St Mancelona, MI 49659
1-800-665-0728
Hope this helps... Good luck!
Sep 22, 2009 | Lincoln Roosevelt Popcorn Maker
ASKO Washing Machine WM220(ASKO 20605)-Control Panel
IS 2 looks like a MOSFET on my machine
I'm not sure on the Manufacturer - Their logo appears to be a large streaked "I"
The numbers on my mosfet read:-
H542
TOP200YAI (this last digit could also be a 1)
PC0288
Cheers from a fellow busted ASKO consumer.. :(
Mine appears to be motor or motor controller related, so if you don't fix yours, I'd be happy to take a few parts off your hands. ;)
Nov 06, 2007 | Televison & Video
Frigidaire washer won't wash
i am a recently retired engineer and based on the info given, you are saying the drum wont go round?, then start with the belt, then the motor carbons, assuming this model doesn't have an induction motor, you didn't quote a model number for me to be sure, if carbons are ok then check the main pcb (module) to see if any thing is burnt or damaged, well thats a start to be going on with, further help if not successful but need more details, model number etc if i have helped rate me please
Sep 08, 2007 | Frigidaire FWTBB30DS Front Load Washer
Lincoln Roosevelt Popcorn Maker Logo
357 people viewed this question
Top Lincoln Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Lincoln Kitchen Appliances - Other Expert? Answer questions, earn points and help others
