Question about Cuisinart DGB-600BC 10-Cup Coffee Maker
Problem with Cusinart DGB600 Grind and Brew Thermal 10-cup Automatic Coffeemaker: Time mode is showing as - - -. Have changed water filter and started over by filling water reservoir, adding ground coffee to basket with paper filter, inserted empty carafe, inserted empty grinder basket with lid. Still did not correct itself to show time. Disconnected unit from outlet and waited two hours. Plugged back in. Still showing - - - in time display. I'm totally baffled. Please offer suggestion. Note: Unit was purchased new 12-21-2008.
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Greetings: Problem with auto grind Cusinart
sounds like the coffee maker had a power surge. Try setting the time again.
1. Setting the Clock When the coffeemaker is plugged in, 12:00 will appear until you set the time. Entering "Time Set" Mode: To set the time, hold down either the "Hours" or "Minutes" button until the clock begins flashing (about 2 seconds). You are now in the "Time Set" mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or pressed and released lightly to advance one digit at a time. When scrolling, the numbers will advance slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting, release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired. Exiting "Time Set" Mode: The "Time Set" mode can be exited in one of two ways: 1. Press any button besides the "Hours" or "Minutes" button. This will exit the "Time Set" and activate the selected function. 2. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Time Set" mode will be exited. 2. Setting the Program Ti m e : When you press the "Program Set" button, it displays the current program time (default time 12:00 p.m.). Entering "Set Program Time" Mode: Press and hold the "Program Set" button (about 2 seconds) until the green light and LCD display begin to flash. This signals that you have entered the "Set Program Time" mode. The desired time can be set by pressing the "Hours" and "Minutes" buttons to scroll forward through the digits. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The coffeemaker will start to brew at the programmed time. The "Program" mode cannot be entered if the c o ffeemaker is in its "brew" cycle. Exiting "Set Program Time" Mode: "Set Program Time" may be exited in any of three ways: 1. Press the "Program Set" button. This will cause the coffeemaker to revert to its previous state. If it was OFF, it will return to the OFF position. If "Programmed", it will revert to this state, and so on. This is a safety feature. 2. Press any other button (except "Hours" or "Minutes"). "Set Program Time" will be exited and the function of that button will be executed. 3. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Set Program Time" mode will be exited and the programmed setting will be in effect.
Posted on Dec 28, 2010
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
My cuisinart automatic grind and brewthermal shuts off every minute or so it douse not brew strate through.
HI,
• Remove the hopper from the unit
• Lift coffee channel cover
• Clean out coffee chute
• Replace channel cover and hopper
• Your coffeemaker is now ready to brew again
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Need manual fordgb300bk
Here is the link (this is for a mac) Cruisinart COFFEE BAR Automatic Grind Brew DGB 300 SERIES MANUAL...
or there is a website called manualonline.com
Mar 16, 2014 | Cuisinart DGB-300BK Automatic Grind & Brew...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
How do I clean the Cuisinart Automatic Grind and Brew Thermal coffee maker
I clean mine once a month with 6 cups vinegar and a couple cups of water. also replace the charcoal filter regularly.
Jan 14, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
-Tha Mp3 Doctor
Aug 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-600BC 10-Cup Coffee Maker Logo
65 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
