Question about Vtech ia5823 Cordless Phone
Message waiting light blinks constantly. also the dial tone gives a stacato tone about 5 times before a clear dial tone is heard.
SOURCE: GE MODEL 28811 DECT 6.0
I have this same problem. Still don't know how to fix it.
Posted on Aug 12, 2008
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
SOURCE: Message waiting light will not go off
Found a user manual online. Solution is holding the "Find Handset" button in for five seconds, until the red light went off; that reset the message waitung light and message.
Posted on Jan 24, 2010
popsgifts
  • 160 Answers
SOURCE: Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 19, 2010
  • 1196 Answers
SOURCE: i have a AT&T model
You can try reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Posted on Mar 14, 2011
Uniden phone light WON'T flash red light when I have pulsing dial tone VM messages.
The pulsing dial tone usually indicates a message on the service provider's server, not on your phone. Contact your provider to find the procedure to access these messages.
Aug 15, 2016 | Uniden Lands Phones
A few of our rooms has the voicemail light blinking. There is not a voicemail waiting and can not be cleared from the front desk or from the room.
Message Waiting Indicator Your phone's message waiting indicator is either a light or special tone that alerts you when you have voice mail.
Occasionally, the message waiting indicator may be out of sync with your mailbox. In that case, the indicator light or tone is ON but there are no messages waiting, or the indicator light or tone is OFF when there are new messages waiting.
To get the message indicator back in sync
  1. Save or delete all new messages
  2. Hang up.
  3. If the message indicator does not go out or stop within a few minutes, there may be a problem, and you should contact Verizon.
  4. If the message indicator does go out or stop, call your own number and leave a message
  5. Hang up and wait
  6. If the indicator light or tone does not come on within a few minutes, there may be a problem, and you should contact the vender.
Jun 08, 2015 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
The waiting light on the phone won't shut off. When the voicemail is dialed there is no tone and the messages can't be checked.
The waiting light is a MESSAGE light. Press MESSAGE and look at the display. It tells you where the message came from and the 3rd soft key will let you CLEAR the message.
Carl
Jul 11, 2011 | Panasonic KXDT343 Phone
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do I turn off message waiting indicator light
The VMWI led will stay lit if you have voice mail service from your telephone service provider. A lot of providers will also give a broken or stutter dial tone when you first go off hook as an indication of messages waiting. If you hear a stutter dial tone when you first go off hook, you will need to contact your telephone service provider. If not, you can try a simple reset on the base unit, just unplug it from teh AC adapter for about 5 minutes and then plug it back in.
Mar 17, 2009 | Uniden 5.8GHz Dual Cordless Phone
Can't get the mesage light to stop blinking
You forgot to supply a model number, but is this a cordless with an answering machine or did the message light blink when you had messages from the phone company provided voice mail?
If it's the former, pressing the play button and/or holding down the ERASE button will make the messages disappear.
If it's the latter, here's where the fun begins. Message lamps are lit from a signal generated from the phone line. Stutter dial tone is usually the cause, and it could be just because you have a feature enabled. I think the cadence of the call forwarding dial tone is enough to set off MW, but I'm not there to hear it :-)
Try unplugging the phone completely, then plug it in without the outside line. I'm guessing the display will tell you there's no outside line, but what does the message waiting light do? Then plug in the line and see if it lights immediately or after some delay. It may test the line as soon as you plug it into the wall and be hearing the funny dial tone.
Comment back after you've done this.
Carl
Jan 07, 2009 | Uniden Cordless Phone
Voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Sep 20, 2008 | Uniden TRU8865-2 Expandable System...
Indicator message light on handheld phones do not go off!!!
on the base set, press and hold the voice mail 1 button. You will get a message clear voice mail indication? hit the sel/save button to the left of the display.
poof! message gone
Apr 17, 2008 | RCA ViSYS 2-Line Speakerphone
Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
Mar 26, 2007 | Panasonic KX-TG5422M Cordless Phone
Vtech ia5823 Cordless Phone Logo
48 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
