Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
Lever won't stay on at low flow rate; lever closes automatically. What can I do to fix it?
  • 349 Answers
Sounds like the retaining ring under the handle may need to tighten a little to stiffen lever a little. To remove handle take plastic red/blue cap at base of lever covering the screw. Remove allen screw that holds handle to base with a allen wrench.
Try to tighten collar that holds the stem for the lever and that should help with the lever. if not the gasket that's under the collar maybe wore to the point that tightening want effect it.
If you need a parts diagram go to this link for an exploded view of the internal parts. I hope this will be helpful to you.
http://www.needplumbingsupplies.com/Danze/Specs/D403412_Inst.pdf page 4 has a breakdown.
Posted on Dec 30, 2010
05 Trailblazer transmission says neutral but gear shiftier is locked in park.
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock control solenoid
• The automatic transmission shift lock control switch
With the ignition in the ON position, voltage is supplied to automatic transmission shift lock control switch. Voltage flows through the normally closed contacts of the automatic transmission shift lock control switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid causing the transmission shift lever to be physically locked in the PARK position. When the brake pedal is pressed the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to be move out of the PARK position.
Circuit Description
The transmission range (TR) switch is part of the park/neutral position (PNP) and back-up lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The powertrain control module (PCM) supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. The PCM compares the actual voltage combination of the switch signals to a TR switch combination chart stored in memory.
These are all electronically controlled , yur best bet would be to take your vehicle to the dealer .
Apr 19, 2017 | 2005 Chevrolet TrailBlazer
Where is location the automatic transmission shift lock relay in my s10 1998 2.2 2wd
Automatic Transmission Shift Lock Control Description
The brake transmission shift interlock (BTSI) system prevents the automatic transmission from being shifted out of PARK unless the brake pedal is depressed. When the brake pedal is depressed, the BTSI solenoid releases a lock pawl. This enables the shift linkage to move and the shift lever to operate.
When service operations are required, the BTSI system can be overridden.
On vehicles equipped with a column-mounted shift lever, override the BTSI system by performing the following steps:
  1. Turn the ignition switch to the OFF position.
  2. Remove battery voltage from the solenoid.
  3. Turn the ignition switch to the ON position.
For vehicles equipped with floor-mounted shift levers, an override lever is mounted on the right side of the assembly. The override lever can be accessed by removing the shift lever boot. Push the lever to the left in order to override the BTSI.
Which does your S-10 have column or floor shift ? No relay ,has a solenoid .
With Column Shift A/T
The brake transmission shift interlock (BTSI) system prevents the automatic transmission from being shifted out of the PARK position unless the following conditions are present:
The brake pedal is depressed.
The ignition switch is turned to the RUN or the START position.
When the ignition switch is in the RUN or the START position, the current flows from the B/U Lamp fuse located in the underhood bussed electrical center (UBEC) through CKT 839 (PNK) to the park/neutral position switch. The park/neutral position switch also feeds the backup lamps portion of the switch. With the transmission in the PARK position, the current flows to the BTSI fuse located in the underhood bussed electrical center (UBEC) through CKT 275 (LT GRN). The current then flows to the TCC/stoplamp switch through CKT 584 (LT GRN/BLK). The current continues to the BTSI solenoid through CKT 1135 (DK GRN/WHT). The ground path is provided through CKT 1850 (BLK) to G207. When the brake pedal is depressed, the normally closed contacts in the TCC/stoplamp switch open and the current flow is interrupted. When the current flow is interrupted, the BTSI solenoid de-energizes. The transmission may then shift to another gear. When the transmission shifts to another gear (except PARK), the contacts in the park/neutral position switch open. This condition stops the current flow to energize the solenoid when the brake pedal releases.
Whic
Jun 09, 2016 | 1998 Chevrolet S-10 Pickup
Shifter is locked in park on a 2002 bravada that sayes on dash its in reverse
PRND321 Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC - instrument panel cluster receives a serial data message from the ECM indicating the gear position. The PRND321 display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the ECM. The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The transmission range (TR) switch is part of the park/neutral position (PNP) and backup lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The PCM supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. The PCM compares the actual voltage combination of the switch signals to a TR switch combination chart stored in memory.
You need a Tech2 scan tool to diagnose this problem ! possible range sensor !
Sep 03, 2015 | Cars & Trucks
I have a 2002 Chevy impala V6 sometime the automatic headlights comes on and sometimes they don't only the parking lights and when I pull out for my headlights to to come on turn off of automatic mood the...
ok when push the lever forward the high beams don't stay on ? then that lever should be replaced cause that's ur dimmer switch to switch between high/low beam lights if the lever is bad can surge you headlight and blow the headlights, have you check headlight bulbs its rare but it has happened that both blow at the same time
Mar 09, 2015 | 2002 Chevrolet Impala
Kohler pop up plug staying closed
The plug has a little hole in the end - that rocker-arm lever fits through the hole. If the plug gets turned 90 degrees to the side before installing the lever, the lever won't go through the holeand the popup won't pop up. Pull the lever back out, rotate the plug 90 degrees with your fingertips or thumb, and put it back in. It may take several tries.
Feb 05, 2014 | Kohler Plumbing
Is Blue Lite For High Beam Supposed T oStay on when clicked?
To clarify, when you pull the turn signal lever towards you, the high beam lights will come on only as long as you hold the lever up. This is the flash to pass feature.
To switch the headlights from low beam to high beam, you push down on the lever towards the dash. Then the high beam lights and the blue indicator light should stay on.
Jun 09, 2013 | Cars & Trucks
Shift lever slips out of drive
try taking the center surround out and checking to see there is nothing under the gear selector stopping it from locking in park
Nov 20, 2011 | 1997 Mitsubishi Diamante
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
Turn Signal Lever 2004 Ford Focus LX
$35 sounds right for the lever. It definitely sounds like it's your lever acting up as the contact seems to be stuck
Oct 02, 2009 | 2004 Ford Focus
Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
619 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
