Question about Dryers
Kenmore elite evenflow with auto temp control starts drying and after a couple of minutes gets an E1 error code. Does not appear to over heat and is not on long when it errors. Does it on all settings.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
E1 code indicates a thermistor failure. You will need to replace the thermistor. Remove the lower panel to access the thermistor. It looks like the picture below...
Part number 8577274, available at https://www.appliancezone.com/SearchProducts.aspx?id=8577274
Posted on Dec 29, 2010
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Code E1 on Kenmore dryer
The electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then if it reads open or the harness of broken. Refer to the detailed troubleshooting of this error code in the link provided below.
Troubleshooting of Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 08, 2010 | Kenmore Elite HE4 Electric Dryer
Have a Kenmore Elite oven. When I try to turn on any of the heating elements, I receive an F5 error. Any suggestions? Thanks much.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite model 16574
press (high temp-wash) button and then ( heated dry)
do that 3 times in that order within 5 seconds. So it looks like this:
(high temp-wash) ( heated dry) (high temp-wash) ( heated dry) (high temp-wash) ( heated dry)
That will start a short diagnostic cycle (last about 2 minutes) that will clear the blinking light and allow you to use the dishwasher. If the light comes back, your drying cycle has failed and you will need service.
Oct 28, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Error E1
I went on another site where I found out that it was a thermistor a part of the heat blower. I will be ordering it for $20 off that site and my husband will fix it.
Oct 06, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer
hi nikid,
Welcome to fixya.com
Huuum at your service,
Did you try to reboot or reset the system as we call it?
Pull the plug, OR throw the breaker off , either for 5 minutes and then restart it.
This will usually reset the error codes and get you back running .
let me know hoe you make out?
See if that fixes the problem by resetting the system.
Bess You Huum
please do mopt forget to leave a rating.
Sep 21, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer will not stay running through entire cycle or it will just stop before clothers are dry and sometimes get a E1 error message. Mostly it will just stop and clothes are not dry, times that is runs...
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Jan 02, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
