Question about Rancilio Silvia Espresso Machine
I had the machine on a timer. It went off early and the brew switch had accidently been on. There was a strong electrical burning smell. I refilled the reservoir, but the machine will not pump the water out of the reservoir. What do you think is the problem.
  • 100 Answers
Your pump is burned out. Open machine and look at fried pump to confirm.
www.dolcevitaespresso.com
Posted on Feb 04, 2011
I left my Artisan espresso machine on between brewing coffee and making hot milk and got an electrical burning smell. Should the machine be switched off if not in use for quarter of an hour or so?
Always off when not being used, it only takes 4 minutes to heat from cold and that can be while you are sorting coffee and cups. Get the electrical smell investigated, these have a problem with seals in the steam boiler which causes switch problems from the steam.
Dec 25, 2012 | KitchenAid Artisan
Dyson animal stopped working and produced a strong smell as if something had burnt out.What could it be and could it be repaired?
hi.
a strong burning smell would suggest an electrical burnout of some kind. could be wiring, switch or motor.
new motors are available for around £35 on ebay. switches are available as well. wire is readily available.
the machine would have to be stripped to find where the problem is (and the cause) and to make sure that there is no heat damage to the casing
it is not a difficult job to do, but i would leave it to a qualified electrician due to the mains electricity.
i have no idea what the electrician would charge in your area.
hope this helps
Apr 03, 2011 | Dyson DC29 Animal Vacuum
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Washing machine filled with water, started agitating, then stopped. smells electrical.
Washing machines are built, sealed so that water or any other liquid that enters into the drums, dryer compartments will be isolated and not penetrate to the electrical system of the unit. There are protections to the motors installed beneath. To give you an idea, a motor mostly installed on it is a split-capacitor single phase motor which is protected by a fuse, thermal overload sensor to prevent burning the winding. A possibilty of electrical burning smells is that, a possibility that the thermal protection of the motor winding didn't open or activate. So that the winding may have been burnt and i'm sure your machine will stop immediately. There is also that timers which are cam driven, there is a strip on the timers and switching between clockwise and counterclockwise rotationion is done here. There is also a possibility that this switches strip may have been warp and burning would have occured due to uneven contact points already, carbonization inside this switches would take place, and your machine would stop. I hope this will help, thanks
Feb 17, 2010 | Kenmore Washing Machines
I used the oven at 425C for about 30 minutes, turned it off, took the food out, left the door open (the fan and light was on. During dinner, we smelled a strong chemical smell, like melting plastic or hot...
your mostlikley correct on the buring wires. The only thing that can be done at this point is to unplug the machine and start tearing in to it to find the bad wires.
Jan 08, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Replaced Motor Coupling but now I have electrical smell when running
You can test the washer with the case removed by by-passing the lid switch. You will need to jumper the two BLACK wires at the lid switch connector (where it connects to the timer).
With the case removed, and the washer UNPLUGGED. Locate the lid switch connector and jumper the two BLACK wires. Plug washer back in and carefully turn the timer on to start. You will be able to visibly inspect the washer while it is running. The Drive Motor should not start running until the washer fills completely. Set the washer on the lowest water setting to reduce fill time. Usually electrical smells are attributed to the Drive Motor and/or Start Capacitor. Make sure the connectors are all on properly and not loose. Loose or corroded connections can cause arcing and/or burning. Inspect all the wiring for any signs of chaffing or burning. Use caution not to touch any of the electrical connections while the washer is running or energized. Running the washer with the case removed is primarily for giving you a visual for any obvious signs of problems. Any wire and connector checks should be done with power removed. I hope this information helps you. Please post back if you require further assistance.
Jun 05, 2008 | Washing Machines
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Rancilio Silvia Espresso Machine Logo
75 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
andy just round the...
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
