Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
My Weathermaker SX Carrier 58SX060-cc-1 sucked snow in the intake and now will not light up. The smaller motor runs whenyou turn it on.
22yooper
  • 828 Answers
SOURCE: Weathermaker SX Carrier 58SX060-cc-1
Your blower motor may have failed. Check the blower motor for the air circulation and you may find it is hot but not running. Have the motor replaced if this is the case.
Posted on Jun 14, 2008
  • 182 Answers
SOURCE: Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Posted on Oct 18, 2008
wbwill
  • 68 Answers
SOURCE: Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Posted on Nov 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: I need to connect a
What is the model # of the thermostat?
Thanks!!!!
Posted on Oct 09, 2010
micromatikal
  • 2777 Answers
SOURCE: My Themostat is a Programble
There is no such diagram.. do you have any idea how to get them all connected? You may be better off just getting a local contractor to wire it and install it. There are so many contractors looking for work you should be able to have it done for less than $60...
That is my recommendation, there is no diagram for the three separate manufacturer devices anywhere to be found, someone would have to draw it.
Thank you so much,
Tim
Posted on Oct 10, 2010
My Carrier Weathermaker 8000 is blowing air out of the air intake. Is there a fix?
Try turning breaker off and back on. Fan is running backwards. Any recent repairs?
Nov 05, 2016 | Carrier Heating & Cooling
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Carrier weathermaker sx (model 58sx040-cc power vent motor and gas velve cylanoid are kicking in and out, do you know what i can do to fix this problem ??
I believe this is the furnace with a spark to light the pilot light. If so the best advice I can give is to replace the whole pilot assembly. There is a very old style flame sensor in there that is not serviceable. This has driven many a technician around the bend.
**NOTE: It is a real pain to get out, and back in. You need to take off the fire box cover and the panel underneath it to get it out. You also need to take the pilot tube off the gas valve. This may be something that you want to call a service tech for. It could be a little tricky and because you are dealing with gas, you want to make sure that it is put together correctly and safely.
Nov 08, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Jun 11, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
If you are running it in the cooling function, your drain maybe backed up. Find your drain outside if you can and suck it with a shop vac.
Nov 25, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
127 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
