Question about Treadmill Doctor Lifestyler Expanse 850 Treadmill Rear Roller
Jazfit T46 Treadmill with error code E0 - Treadmill Doctor Lifestyler Expanse 850 Treadmill Rear Roller
I have a Jazfit 5333 treadmill - the speed and time are not working - led is fine but does not show time or speed just random numbers flash...how do I fix this??
Sounds llike you may have problem with your speed control module which will also be linked to yr time display . Call a treadmill tech for quote & availability of parts cost labour & service
Mar 02, 2015 | Exercise & Fitness
Jazfit 4400 error 7
Sounds like it is time to replace the entire lift mechanism. Usually something like that would have a kit available for such repairs., I'm sure that'a not the first one to go bad. Call our local dealer and find out what the procedure for repairing the lift screw. You can probably pick up n after market replacement at a local parts house a lot cheaper than from a dealer. Good Luck.
Col. Dana Gillespie
Jul 05, 2014 | Office Equipment & Supplies
Jazfit top 49 treadmill
Are you sure its E S and not E 5
Dec 16, 2013 | Exercise & Fitness
Fix error 2 treadmill
this is a probably a faulty sensor speed see the diagram attached. However depend of your mark , model, can be e1 ,tight the connector very well, and clean it. Test the s.speed for open or faulty.
Oct 19, 2013 | Exercise & Fitness
Jazfit txo
see the video and proceed according. Lube the rollers bearing front+back with silicon or wax( depend of your mark, model) read your owner manual.
God bless you
Oct 18, 2013 | Icon Epic T60 Treadmill
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Treadmill GK1305FI showing E0 error on startup
Dear Sir:
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
Use too the calibration software see under The Hood Motor instructions or use the user manuals.
sincerey. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Treadmill Doctor Lifestyler Expanse 850 Treadmill Rear Roller Logo
181 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
