Question about GE WPRB9110WH Top Load Washer
GE WPRB9110WH Top Load Washer The control panel buttons work erratically. you have to press and manipulate them to get the cycles or any of the options to work
    President:
  • 3,113 Answers
You may have to take the control overlay off of the control unit and clean and dry it so it will make good contact.GE WPRB9110WH Top Load Washer
Posted on Dec 29, 2010
Front loadin washer says control locked!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked how do I unlock?
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock is on. How do I get it to unlock so I can turn on dryer
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Mar 12, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
It said contorls locked and will not work. I tried to unplug and reset no luck.. any suggestions please!!!!!
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washingmacine stopped working completely. it started with one cycle going out , then a week later another cycle stopped working. now none work. when i turn the machine on i can here a hum , but nothing...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.))))
Feb 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine smells like something burning while load was washing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((
Dec 19, 2009 | Maytag Legacy Series Top Load Washer
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Control lock on model ghw9100
Try pressing and holding the "End of Cycle Signal" button in for 3 seconds. This button is used to lock/unlock the control panel as a safety feature to prevent small children from manipulating the controls. The instructions should be printed on the front panel near the button.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I am getting "CI" on the display even with an empty load cycle?
Jan 12, 2009 | Kenmore 20172 Top Load Washer
GE Washer
have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Feb 17, 2008 | GE WPRB9110WH Top Load Washer
GE WPRB9110WH Top Load Washer Logo
70 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
