No audio device is installed? samsung R519. - Computers & Internet
2 Suggested Answers
  • 2905 Answers
SOURCE: new samsung r519. integrated webcam works fine
est your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Posted on Dec 19, 2009
How to do a system restore
Have you rebooted the Laptop? shut down, unplug, remove battery, plug in, reboot, the device should install the device. Open Device Manager, look for Network Adapters, open Is the wireless device there? Post results. If no right click network adapters and Scan for Hardware changes. You can find the Wireless Adapter driver here, select the correct OS: http://www.samsung.com/uk/support/model/NP-R519-FA06UK-downloads
Mar 01, 2013 | Samsung R519-53S Notebook
I have installed windows 7 to my laptop but my wireless has been turn off
Maybe it will work again if you install the driver for wireless internet:
Select driver - Windows 7 - Wireless LAN,ATHEROS
Dec 17, 2012 | Samsung R519-53S Notebook
Samsung r519 usb ic
All USB not working? If not remove USB device re-boot and then re insert USB device. Still does not work check Device Manager look for any errors under the USB list. That said, how old is your Samsung and what are you using in your USB port?
Oct 29, 2012 | Samsung R519-53S Notebook
Factory reset samsung r519 laptop
RTM - Read The Manual.
Your manual says if you can boot into windows then click Start/All Programs/Samsung/Samsung Recovery Solution
If you cannot boot into windows when you turn the computer on hit the F4 key.
The link below will take you directly to your manual
http://www.samsung.com/us/support/owners/product/NP-R519-FA01US
May 01, 2012 | Samsung R519-53S Notebook
I cant be able to browse the internet using my samsung r519 laptop
It depends on the browser and the network ..
assuming all its ok ..than the internet connection may be faulty ..check to have all drivers for the device you use to connect .The LAN driver for cable connection and the wireless driver .The drivers should be on the cd that came with the laptop ..or download them from the manufacturer's support site ..
http://www.all-driver.com/notebook-driver/samsung-r519-53s-notebook-driver-xpvistawindows-7-download.html
You also have them here ..select the last ones for windows 7 and install them again (the LAN and wireless drivers)
after that be sure you make the connections right ..if you have a static Ip you need to insert them and for that contact your ISP .
Nov 21, 2011 | Samsung R519-53S Notebook
Samsung r519 operating system not found windows 7
PROBLEMS IN HARD RIVE DRIVERS
RE INSTALL WINDOWS 7 AGAIN
May 11, 2011 | Samsung R519-53S Notebook
Usb ports not working on r519 laptop
This is most likely because your motherboard's driver is not installed. Head on to this site :
http://www.samsung.com/us/support/downloads/NP-R519
Click on "driver" and then download the file which says "Chipset". Make sure you download the one which matches your version of windows. Run it and restart your laptop. Your USB should work after that.
Mar 11, 2011 | Samsung R519-53S Notebook
HOW DO I SET UP WEBCAM ON SAMSUNG R519?
Make sure you install the right webcam drivers, and then start a program (like a messenger) to use it. Just select the webcam as the video input device, and is should get activated automatically.
Sep 12, 2010 | Samsung Computers & Internet
Webcam On Samsung R519 LAPTOP NOT WORKING ON MSN HELPP!!!
Download and install Adobe Flash Player. Worked for me
Nov 08, 2009 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
