Question about Zanussi Dishwashers
Hi, our zanussi ZDTS101 will not start a new programme, the normal end of programme is flashing and the programme selected but it wont start when we close the door. The end of programme button is constantly flashing
  • 1294 Answers
SOURCE: Zanussi Washing machine
Try some WD40 on the door switch.
Posted on Jan 25, 2008
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
IFIXALL
  • 868 Answers
SOURCE: whirlpool adg 7540 fills,washes, drains
replace electronic control.
Posted on May 20, 2008
SOURCE: Door not closing Zanussi FX1265W 1200 Auacycle
Further to my previous posting, I have now got a new Bosch but I have removed the PCB from the FX1265W. I found that the printed circuit track between the edge connector and the triac has blown. The triac (BTB16) was tested and faulty. New triac is on order (£1.03). I will post again when it has been fitted and the track is repaired and if the machine works.
Mark Allinson
Posted on Aug 22, 2008
  • 116 Answers
SOURCE: Zanussi Electrolux FX 1265 W washing machine wont work
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
Posted on Sep 20, 2008
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
May 14, 2010 | Dryers
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
Mar 25, 2010 | Dryers
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
Chrisbounty
Sep 20, 2008 | Washing Machines
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Dishwashers Logo
93 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
