Question about Sylvania G-Netbook
Not able typeon keypad - Sylvania G-Netbook
    Genius:
  • 1,267 Answers
Try resetting, by turning the machine over on its back and finding a small hole about 1in from the data plate right lower diagnal. Insert a toothpick into the hole and press the micro button untill the machine cuts off, it will come back on and load a fresh copy that may work, if not read my TIP on flashing found at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Posted on Dec 29, 2010
Keypad prpblem
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Sep 27, 2012 | Cell Phones
Bro i have samsung t509s.keypad doses nt work.i did not find keypad ic.sir can tell meh where is keypad ic?
Oct 20, 2011 | Samsung SGH-T509S Cellular Phone
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
The keypad function not respond when i push it, so i can't unlock the keypad, what can i do with my nokia 6120c?
Hi, what causes the keypad not to function is that, the keypad might be dirty or the keypad IC that controls the function of the keypad might be damaged.
You can unscrew the phone and clean up the keypad area and see if it will function.If it doesn't function,that means the keypad IC inside the phone is damaged and will need replacement.
Have a nice day.
Sep 13, 2010 | Nokia 6120 classic Cellular Phone
How do you test a voltage regulator (built in typeon alt)?
you have to take off and take it to an auto parts store. they will check it for free
Jun 21, 2010 | Cars & Trucks
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Lock 9 light is on
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, hold down <Fn> and press the desired key.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Mar 20, 2009 | Dell Latitude D410 Notebook
Ican"t type numbers can you please help
From Dell user manual:
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Jan 13, 2009 | Dell Inspiron 6400 Notebook
2003 ford futura programming a new keypad
Adding and Removing remote Keypads to the Smartlock module
Up to four Keypads can be programmed and used with the Smartlock Remote
Central locking system.
If you have replaced the BEM, or new keypads are being added to the
system, you will need to train the keypad codes to the module.
# 1. The ignition switch should be in the Off position, with all the
doors shut and Unlocked.
# 2. Turn the ignition key to the ACCESSORY position and within 5
seconds, operates the rear demister switch exactly three times in quick
succession. (IE. Press the switch so the Demister light turns on, then
off, then back on again.)
# 3. After the 5 seconds is up, the door locks will change state, to
indicate that the BEM has entered keypad learn mode.
NOTE : All existing keypads at this point, have been erased from memory
# 4. Press either buttons on the keypad that is to be trained. The door
locks will change state twice, to indicate that the keypad has been
added to the BEM memory.
# 5. Follow step 4. for each keypad that is to be added to the BEM
memory. A maximum of 4 keypads can be added to the BEM memory.NOTE :
You must teach all remote keypads for the Smartlock module, before
proceeding.
# 6. When you have taught all the remote keypads, turn the ignition to
the Off position to leave the learn mode. The door locks will change
state to indicate a return to normal mode.
# 7. Check the function of both buttons on each keypad, to ensure that
the keypad has been trained.
Sep 15, 2008 | Ford Futura Cars & Trucks
How do I use Dell inspiron 1300 keypad?
If you are referring to the Number keypad.
Tap the "Num lock" key and you will see a light flashing.
Make sure the light is on when you stop.
Now try the keypad.
Mar 15, 2008 | Computers & Internet
Sylvania G-Netbook Logo
18 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
