Question about Amana LW8203
Amana lw8203w2. when in wash mode (i guess this is known as aggitate mode) the tub spins fast counter clockwise.
  • 2 more comments
  • dweckrichie Dec 29, 2010
    thank you, i will order the parts and give it a try.
  • dweckrichie Jan 04, 2011
    i got the brake pads and i am about to change them. i also got a new belt and i would like to change it however i dont know how to take off the old belt. how does it slide out? please advise?
    i also got a new belt< but i dont know how to slide old belt out. please advise.
  • Anonymous Mar 12, 2014
    aggitatoronly spins clockwise
  • Amana Master
  • 2,605 Answers
Welcome to FixYa.
It sounds to me what you're describing is worn brake pads on your washer's gearcase, thus not holding the basket while the unit agitates. It is actually fairly common and regular wear over time.
You can purchase the pads at most brick & mortar appliance parts depots or on-line parts vendors such as "repairclinic.com" or "searspartsdirect.com" to name a couple for around $20USD.
**Unplug the washer from the wall before performing any service...safety first**
If you pull the front panel of the washer off and look at the bottom of the transmission...above the belt pulley you should see three carbon pads as these shown here...
Everything in the image is included in the kit as well as instructions to install them. If you follow this link you can observe an exploded illustration of the components I'm referring to as well...
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fI2204660-00013.png
Installing the new pads is actually really straight forward and requires only removing the old ones, and it isn't too difficult with a little patience and a small socket set.
Hope this helps move you forward. Let me know if I can assist you further and I will try and help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Dec 29, 2010
  • Mark MacDonald
    Mark MacDonald Dec 29, 2010
    Great, let me know how you manage...keep me posted.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Jan 04, 2011
    Hello again,
    Hope you haven't waited long, i was watching a hockey game and so i just got your message.
    The best and easiest way to install the new belt is to unfasten the motor bracket from the base, then undo the pump as that will allow the pump to come off.
    ( t may need to be wiggled bit as it can get stuck on the shaft, or a spray of WD40 or equivalent on the shaft will usually work too )
    Then you can loop the belt around the motor pulley, reinstall the pump, then the motor. From there you should be able to rap the belt around the drive pulley, belt tensioner.
    I'd suggest you take few photos or draw a diagram of how the old belt is routed before installing the new one, but other than that you should be good to go.
    **Of course turn the power off or unlug it from the wall...safety first**
    Regards,
    Macmarkus :)
Spinner on twin tub washing machine not spinning
I have had a manatee twin tub washing machine with spinner for two years. When I went to spin dry the first load this evening, it would turn on, but not spin. I read the above entry about another twin tub. I did the following... I unplugged the machine for 1 minute. Plugged it back in, then slowly and carefully turned the spin tub clockwise for 1/4 turn, then counter-clockwise for 1/4 turn. I cannot explain why it worked, but it did. So, try this trick before taking it apart. Good luck!
Jan 15, 2012 | Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Feb 28, 2009 | Amana LW8203
Front load drive motor on Kenmore washer will only turn the drum in a counter clockwise direction an there is no fast spin
you could have choosen the gentle care mode or delicate mode where in it would only run in one direction and would spin slowly.
tnx 4 using fixya,
drcool
Jul 28, 2008 | Whirlpool Washing Machines
GE washer model WHDSR209
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
Jul 15, 2008 | GE WDSR2080D Top Load Washer
Amana washer
take the front panel off, two screws at the bottom of the front panel, probably a 5/16 nut driver will work. You will need a flash light. partially fill the washer with water and then turn it to spin.
Look up underneath the tub and see where the water is leaking from. If its coming from above the bearing you need a seal job.
Bearing, seal kit, not cheap, how old is the machine, time to buy a new one?
T
May 12, 2008 | Washing Machines
PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Mar 24, 2008 | Bosch WFLI 2440 Front Load Washer
Washing Machines Logo
147 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
