Question about Fisher Price Infant to Toddler FP906355 Standard Stroller
Real wheels are stuck & so i can not removed them...please help as pram wont fit into my car boot without the real wheels off.
I had the same problem with one rear wheel. Have you tried WD40?
Posted on Oct 05, 2008
Jane Rider front wheel swivel problem....they get stuck.
We have had exactly the same problem. We took the pram back to where we purchased it from and got the pram fully serviced, the back tyres were changed for a better quality all terrain one, and the front tyres were also changed with new bearings fitted. It works as good as new now, however I still think this is only a temporary solution... Interestingly we have only used the pram (from new) for just four months before the tyres completely deteriorated and we found the manoeuvrability a major problem.
Jun 28, 2012 | Jane Rider Pushchair in Buganvila
1998 ford ranger wont reverse, the right real wheel wont spin but the left real wheel spin. It can only drive forward but not in reverse. Please help us on how to do it yourself.
either brakes are seized or the wheel bearing is seized. most likely the brakes are what seizes up. just jackup, and take tire off to check it out. it maybe a stuck brake, rust or dirt, or maybe a broken spring or two. good- day ! but first reach in back of tire and pull on the e-brake cable a few times at the problem wheel, it may be binding.
Jul 20, 2011 | 1988 Ford Ranger
Hi, when I open my Bagaboo Frog stroller and flick the front (small wheels) out, they dont lock into place. This means when i am walking if I lift the pram up to go onto a curb, those small front wheels...
The chassis is locked by the seat or bassinet unit clicking down onto the black prongs that stick up from the central hubs. It would be mechanically impossible for the front wheel assembly to swing back if the seat was fully engaged into the hub as it has a large plastic block that fits into the hubs to lock them. Remove the seat check for any obvious damage, spray some silicone spray on the prongs and the square white lock buttons. Wipe of excess with a paper towel than try to fit seat again. macnutz_13.jpg
Jun 24, 2011 | Bugaboo Frog Stroller
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
Can this be folded down to fit in a car boot in pram mode
I assume that you mean when the pram is in the bassinette mode (for a newborn)?
The answer is yes. I would suggest that prior to folding, ensure that the pram is laying completely flat and that the hood is folded down flat too.
I hope this helps.
Sep 25, 2009 | Silver Cross 3D Stroller
How do you collapse the buggy?
At the footplate, either side there is a black plastic button. These buttons are pulled up and the pram will collapse. Keep the wheels on swivel mode so that they tuck neatly underneath and then move the handle bar to it's lowest height, then the pram will fit neatly into your boot.
I hope this helps.
Aug 15, 2009 | Mountain Buggy Urban Elite Double Stroller
I am looking for wheels for an emmaljunga pram
Try E-bay, These great Prams are now real cheap to purchase, you may even pick up a complete pram to use as spare parts.
May 19, 2009 | Baby Gear
Navy and white silvercross dolls pram bought 1980 new
I know exactly what you mean about the classic Silver Cross look but if you fit two larger diameter wheels the pram would not sit level unless one of the axles was repositioned to compensate.
Wheels have been retained by a number of methods and then hidden behind a (usually) chrome cap that must be carefully prised off. In more modern times it has become usual to combine the chrome cap with a spring retainer. It is fitted with the gentle tap of a mallet but patience is needed to remove it and no small amount of carefully applied force and even then there is about a 50% breakage. It is possible your pram used these.
Apr 18, 2017 | Baby Gear
Silver cross 3d pram system in jet sport
i have a silver cross travel system and can only seem to fit the rain cover on properly when its in pram mode how do you do it when the car seat is attached
May 01, 2008 | Silver Cross 3D Stroller
Fisher Price Infant to Toddler FP906355 Standard Stroller Logo
140 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
