Question about Nikon COOLPIX S230 Digital Camera
I have yellow lines across the screen? - Nikon COOLPIX S230 Digital Camera
Yellow black and white lines streaking across the screen
tyr to factory reset device on advance settings
with out the memory card
Apr 29, 2010 | Casio Exilim EXZ75 Digital Camera
I have a yellow line going across the top of my screen
open the back of the tv, put a heavy blanket over the screen and adjust the knobs inside the tv until the lines are bright, solid and straight
Dec 10, 2009 | Televison & Video
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
3 yellow horizontal lines in upper 1/3 of screen on Sony KP-61S75
TV has problem in convergence circuit. Needs qualified technician.
Aug 03, 2008 | Sony KP-61S75 TV
Blue circle across top of tv screen & maybe some yellow
Good Day,
Does the blue spot have tin white lines?? Is there a picture behind the 'circle'? You may a blue crt (tube) problem.
Jun 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Yellow Line at the Top of Screen
Try doing a system reset. Not sure it that's the term they use but that option basically resets the tv to factory default settings. It's in the menu somewhere. I've done the reset twice already for a similar problem. Solved it each time.
Jun 05, 2008 | Toshiba 42HP95 Television
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Nikon COOLPIX S230 Digital Camera Logo
63 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
