Question about Cameras
My camera always indicate a busy mode . cannot shoot
  • 747 Answers
A busy mode after you have made a shot or when you are about top make a shot? Could be as simple as formatting the SD memory card and or the card is locked here is a diagram to unlock the card but, you still should format the card in your camera.
Unlock card diagram here
Posted on Dec 29, 2010
How do I get a wireless remote to work? I have read the manual but still do not understand how to use it. I am new to this camera and learn better hands on than reading a book.
Assuming you're referring to the ML-L3 remote, you need to set the camera's shooting model to one of the two remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
To change the camera's shooting mode, press the shooting mode button (overlapping rectangles) and turn the main command dial (on the back of the camera). The quick-response remote mode is indicated by a picture of the remote. The delayed remote mode is indicated by the remote and a one-handed clock.
The remote needs to be pointed in the general direction of the receiver on the front of the camera, above the "D70" nameplate.
Jul 31, 2011 | Nikon D70 Digital Camera with 18-70mm Lens
Cannot shoot. always busy
I don't understand your question you are showing a 35mm film camera model and saying it's always busy or you are always busy. To properly answer your question I'll need more information
Dec 29, 2010 | Canon EOS Rebel G 35mm SLR Camera
Busy message and will not always shoot continuously
First, make sure it is set to continuous shooting.
Second, if you get a busy message, your buffer is probably full. This is a limitation of the hardware, and there might not be much you can do about it.
Jun 16, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
What is the hand icon on the bottom right side of my camera mean? (It's not the shaking camera icon) I can't find it in the user manual anywhere. It's a solid white hand.
See pages 20 and 39 in the manual. According to this, the hand symbol indicates that you have Image Stabilization set in the 'Continuous' mode (always on). The other modes available are 'Shoot Only', 'Panning' and 'Off'. You select the desired mode at 'IS Mode' on the Menu for Record (camera silhouette at the top) .
Feb 25, 2010 | Canon PowerShot S3 IS Digital Camera
My eos40d on sports mode is not shooting at its proper speed at 6.5 frames per second. it shoots 2 frames per second and the piture cones out orange and not focus I only have this camera four weeks any...
6.5fps is only the manufacturer's indicative maximum. The camera will not always perform at this speed when conditions aren't suitable (too dark, for example). In Sports Mode, the camera decides the correct shutter speed for that scene. If it's not a very bright day, shutter speed has to be lowered (slow) to compensate for the lack of light. This results in a lower frame per second.
If you want to test the max fps, set your camera on Tv, and set the speed to 1/1000+ on a bright sunny day. Set the Drive Mode to AI Focus or AI Servo. If at 1/1000th of a sec, the Aperture value blinks in the viewfinder, you don't have enough light. Increase the ISO. You should be able to achieve 6.5fps. That's my experience anyway. Good luck.
Sep 18, 2009 | Canon EOS 40D Digital Camera
Scrambled image in shooting mode-Canon A85
It is problem of bad CCD Imager in your Canon A85 camera and ccd imager will be replaced to get correct picture in live view/ shooting mode.
Canon will repair your camera free of cost. Click Canon CCD Imager Advisory for details.
Thanks.
Sep 08, 2009 | Canon PowerShot A85 Digital Camera
Canon camera shake indicator always on.
No it's not indicating shake. It's just telling you that the image stabilizer is on, and set to "continuous".
Jul 10, 2009 | Canon Cameras
Nikon D80 Camera
During shooting, or when the shutter-release button is pressed halfway, the number of images that can be stored in the memory buffer at current settings is shown on the exposure-count displays in the control panel and viewfinder. "r06" indicates that six images can fit in the camera's buffer, "r08" would indicate eight frames. Any other number could be displayed as well. Burst mode is used when you want to hold down the shutter button and continuously shoot. You are probably shooting in burst mode and your buffer is full, set the camera to single shot and see if that helps.
Jul 02, 2008 | Nikon D80 Digital Camera with 18-135mm...
Memory card error
Zeru
I have a similar problem with one of my older memory cards. I have replaced it with a newer one. I don't have the problem any more. I keep the old card as an extra, knowing that it will only store a few photos.
The comment by the GUEST sounds like a different problem. That problem sounds like the "memory card switch" is locked. This is physical switch on the memory card itself, and will not allow writing to the card.
Dec 19, 2007 | Canon PowerShot A450 Digital Camera
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Cameras Logo
171 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
